Any way to 'Smoke' a red tail light?
Old Nov 10, 2013 | 05:40 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
I mistakenly picked up a red center tail light filler for my '84 Trans Am which has the smoked tail lights. My bad. Is there any way to tint/smoke the red one to match? Hard to find any of the '82-84 center fillers in decent shape.
Old Nov 11, 2013 | 05:54 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: Any way to 'Smoke' a red tail light?
You can tint it by sanding it down and clear coat it, mixing a small amount of black in the clear coat. It may turn out too glossy, I'm not sure, but the color should be closer.
Old Nov 11, 2013 | 07:56 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I have done a lot of them I take black and gray and mix them until you have the right color and over reduce it like 500% then spray 5-6 coats then clear but I think you can get a kit at the parts house that is in a spray can if that would be better for you (and if its just blacked out then dont use the gray)
Old Nov 12, 2013 | 05:43 PM
Hal87's Avatar
Thanks guys. Ramsey, may give the 'kit' a try if I can't find an original in good condition soon. Love this forum!
Old Nov 20, 2013 | 05:12 PM
cz28coptzer327's Avatar
Car: 84 camaro Z28
Transmission: borg warner T5
couldnt you use the VHT nightshades on that?
Old Nov 22, 2013 | 11:04 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Nightshades is hit and miss. I had to use adhesion promoter in mine to make the clear stick.
I prefer putting one or two coats on with a detail gun mixing a little black in the clear. Then follow up with straight clear. Worked fine for me and I didn't have as many issues. Apparently that's what a lot of body shops do as well. Just gotta watch how you overlap while you apply the tint so you don't have dark bands across the lights.
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
