Where can I find this?????
Old Nov 14, 2001 | 04:57 PM
Luv_my_84camaro's Avatar
i just finished redoing my interior and everything perfect except that in the inside when i get going about 40mph w/ the windows up i can hear what sounds like i barely have my window open but i discovered it was a black, triangle piece that had cracked from being in the sun. Located on the top of the door up kinda in between the window and wind sheild. I've looked everywhere and i can't find the piece. I don't know if it can come off the door. I just need to know if i can buy just that individual piece and put it on
Old Nov 14, 2001 | 05:12 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I had to replace that piece. You can get it from the dealer. they sell the triangle and the weatherstrip for it separately. That piece can come off the door, to do so you must take hte door panel off, and there are like 2 or 3 10mm bolts which hold it on.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
[This message has been edited by Ward (edited November 14, 2001).]
Old Nov 16, 2001 | 01:20 AM
toosloz's Avatar
i believe you are talking the corner door piece....
is it on the very edge where it meets the weather strip?
if its that.....you can yank it out and its easy to replace....
just open your door and yank upward on it...take a look in a junk yeard..they are ecerywhere....or if you want new take a look in classic industries...they are like $33?
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
14.3@95mph
http://www.geocities.com/toosloz/84camaroz28.html
ChristinaMarie
Sep 11, 2015 06:28 PM
NiG
Sep 7, 2015 11:25 PM
Street Lethal
Sep 7, 2015 01:09 PM
