REAR BUMPER SHAVE
Old Nov 20, 2013 | 08:57 AM
  #51
KBD85's Avatar
Car: 1985 trans am
Re: REAR BUMPER SHAVE
Here i am showing that you need to grind the s#!t out of the surface, (24 grit on a grinder and very low RPM). This panel bond is amazing, but you HAVE to have a rough surface to get this to bond realy well. I also am showing the importace af measuring and allignment. using dimension tape works awesome!!! so i have to come down 1-1/2 inch so therefore i use tape that wide to mark its location. also you will see the thin green line tape. I am screwing this on a curved surface, you need to keep your screw line the same, as if you have a high or a low screw in the screw line you will get warpage becouse it will pull the pannel down differently. Use a nice straight line (the green tape in my case) to put your screws in a straight line. (i hope that made sence)
Attached Thumbnails REAR BUMPER SHAVE-051.jpg   REAR BUMPER SHAVE-052.jpg   REAR BUMPER SHAVE-053.jpg
Old Nov 20, 2013 | 09:02 AM
  #52
KBD85's Avatar
Car: 1985 trans am
OK... next three pics, lets see. Here you can see the 3M gun needed for the panel bond. i put a bead on both the bumper and the parts im attaching. this frontal work is getting it all solid and in shape. When i am done on the face i will take it off again and reiforce it with way more panel bond than i will ever need, but im paranoid! hehehe therefore i make sure its gona be solid. and also if i shape it i want to have enough strength if the cover gets thin. As you can see at the top of the exising cover where it meets my filler piece i will be grinding that down a bit to match the body line that is mid drift around the whole car. this is the point where it will cut back down and in twards the car on its way down. Again i feel like this is way wordy and confusing, so plese ask any questions you need to clarify what the hell im trying to say
Attached Thumbnails REAR BUMPER SHAVE-054.jpg   REAR BUMPER SHAVE-055.jpg   REAR BUMPER SHAVE-056.jpg
Old Nov 20, 2013 | 09:03 AM
  #53
KBD85's Avatar
Car: 1985 trans am
just two more to show some different views. i hope in the next few days to work over the corners. OH.. i wanted to mention the screw spacing should be about two inches apart to get the panels nice and tight.
Old Nov 20, 2013 | 12:40 PM
  #54
Marc 85Z28's Avatar
The rear 91-92 Z28 spoiler is RUINING it. Either lose it completely or get the back of it to match the new bodyline you're creating.
IMO those spoilers don't work with any 3rd gen, not even the cars they were originally installed on. It's like the guys that put 4th gen WS6 inspired hoods on their cars - YUCK.
Old Nov 20, 2013 | 01:19 PM
  #55
KBD85's Avatar
Car: 1985 trans am
hmmm, i kinda like it, but im curious what you mean by the back of it to match the new body line. im still up in the air on which one to use, i have two other hatchs all with different fins that i will set on there to see how it looks. so im not totaly sold on this fin. it just happens to be the hatch i have sitting on it at the moment. so PLEASE!! keep the comments coming. and do you have one you think looks the best?
Marc, i think i know what your talkin about, if i kept it your talking about making the back flush kind of like a ferrari f 40.
Old Nov 20, 2013 | 01:36 PM
  #56
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
I like the Idea is going to look somelike a corvette. Good work
Old Nov 20, 2013 | 01:45 PM
  #57
KBD85's Avatar
Car: 1985 trans am
thanks! yeah that is kind of what i was thinking. i have the origonal just incase i want to go back. I realy like is so far, not sure if im sold on it just yet.
Old Nov 20, 2013 | 01:48 PM
  #58
carattini's Avatar
Car: Pontiac 89 GTA
I'll like o see some diffusers in the end will look even better with that look.
Old Nov 20, 2013 | 03:33 PM
  #59
KBD85's Avatar
Car: 1985 trans am
dangit Marc!!!! now you have me totaly thinking of building a fin. im thinking just like you said, flush with the back end. hmmmmmm i think that would so tie in the whole shaved rear bumper look.
Old Nov 21, 2013 | 07:54 AM
  #60
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I'm building a new wing now that might work with it. I'm still finishing it, but the shape is done. I designed it to be flush with the deck lid. I'll get a pic of a test fitting session soon.
Old Nov 21, 2013 | 08:02 AM
  #61
KBD85's Avatar
Car: 1985 trans am
oh i would LOVE to see it!!! i like the idea, what fin did you use as a base?
Old Nov 21, 2013 | 12:31 PM
  #62
KBD85's Avatar
Car: 1985 trans am
alright, at lunch i ran home to check out the corners, i got one side cut out, so i can do the other now. here are a few pics. i think i can get the whole outer put together now, then i can take it off, make sure the inside is good, reinforce a few spots and grind to shape!
Attached Thumbnails REAR BUMPER SHAVE-z059.jpg   REAR BUMPER SHAVE-z060.jpg   REAR BUMPER SHAVE-z061.jpg
Old Nov 21, 2013 | 01:37 PM
  #63
1Aauto's Avatar
Former Sponsor
Coming along pretty good!
Old Nov 21, 2013 | 01:40 PM
  #64
KBD85's Avatar
Car: 1985 trans am
thanks Tony!!!!!!
Old Nov 22, 2013 | 07:24 AM
  #65
stealtht/a's Avatar
Sorry couldn't get a pic of the wing yet, started dumping snow.
To give you an idea, I used the stock flat firebird wing as a start, it's trailing edge is the same contour as the rear edge of the deck lid. I lifted it up about 6" off the deck, extended the side canards and the wing bends down on either side. The trailing edge is still flush with the deck lid. The rough mock up is almost done, haven't figured out the uprights yet, I'll try and get a pick soon. I'll make a mould of the plug when it's done so I'll be able to make it out of a variety of materials.
Old Nov 22, 2013 | 07:27 AM
  #66
KBD85's Avatar
Car: 1985 trans am
no problem! your good. that is what i was thinking, using the small stock fin. i have one of those i can use. thanks!!
Old Nov 22, 2013 | 07:59 PM
  #67
KBD85's Avatar
Car: 1985 trans am
OMG!!!!!! this build "looks" so simple.... ITS NOT!!!! i thought i had it how i wanted it and the body line on the back pooched out like a full diaper!!! i had to cut a slit in the small upper area and tuck the pooched out area in to match the way the body line flows. anyway i have a pic of before and after. in the pic it is hard to see, but in real life it looked aweful (the first pic). it looks really really good now finaly!
Ken
p.s. how bout a small poll / oppinion here. should i shave (fill) the "pontiac" depression above the licence plate box? or leave it??????
Old Nov 23, 2013 | 09:18 PM
  #68
KBD85's Avatar
Car: 1985 trans am
Well,,, i finaly like the shape ive got. Like i said before, this one has been a bit tricky to get right. i think im going to bring a "hard" line down the corners. It will be a little soft, kind of like the tight roll at the upper back of the quarter panels. the bottom i still need to rought in. but i got the top portion how i want it. Just thought i would post some pics of the progress.
Ken
Attached Thumbnails REAR BUMPER SHAVE-z064.jpg   REAR BUMPER SHAVE-z065.jpg   REAR BUMPER SHAVE-z066.jpg
Old Nov 23, 2013 | 09:19 PM
  #69
KBD85's Avatar
Car: 1985 trans am
a few more pics
Attached Thumbnails REAR BUMPER SHAVE-z067.jpg   REAR BUMPER SHAVE-z068.jpg   REAR BUMPER SHAVE-z069.jpg
  #70
KBD85's Avatar
Car: 1985 trans am
and two more.
Old Nov 23, 2013 | 09:27 PM
  #71
LX_SS's Avatar
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
very nice, i'm liking where this is headed :-)
Old Nov 24, 2013 | 01:40 AM
  #72
karl's-92'-z28's Avatar
Car: Too many cars
I think for the rear wing, something along the lines of the Hawks 5" camaro spoiler.
Old Nov 25, 2013 | 11:31 AM
  #73
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
That's looking good. Nice job
Old Nov 25, 2013 | 12:35 PM
  #74
KBD85's Avatar
Car: 1985 trans am
It sure is being a difficult one! I am finally liking how it is looking. Still up in the air if I totally like it. I hope to paint it this week. Then I can put it on and see what I think, and of course all of you guys too!!!
Old Nov 25, 2013 | 12:46 PM
  #75
Project-RS's Avatar
I'm modifing my rear bumper also. Converting to a free air style. As far as spoiler, it can go either way. I took mine completely off and waiting on a style I like or to not put one back on
Old Nov 25, 2013 | 01:35 PM
  #76
KBD85's Avatar
Car: 1985 trans am
Yeah I can't decide on the spoiler. There have been really good suggestions, I just have to decide. I may fab something.
Old Nov 26, 2013 | 06:56 PM
  #77
KBD85's Avatar
Car: 1985 trans am
Alright guys!! here we go!! im feeling realy good about this build now. It is coming together finaly. It has cost about a third more in products tho!! i guess thats the price of custom one off stuff. well, enough bla bla bla... heres a bunch of pics. Im going to prime in the next day or so. Depending on how the holidays pan out.
Ken
Attached Thumbnails REAR BUMPER SHAVE-z072.jpg   REAR BUMPER SHAVE-z073.jpg   REAR BUMPER SHAVE-z074.jpg
  #78
KBD85's Avatar
Car: 1985 trans am
more...
Attached Thumbnails REAR BUMPER SHAVE-z075.jpg   REAR BUMPER SHAVE-z076.jpg   REAR BUMPER SHAVE-z077.jpg
Old Nov 26, 2013 | 06:57 PM
  #79
KBD85's Avatar
Car: 1985 trans am
and more...
Attached Thumbnails REAR BUMPER SHAVE-z078.jpg   REAR BUMPER SHAVE-z079.jpg   REAR BUMPER SHAVE-z080.jpg
Old Nov 26, 2013 | 06:58 PM
  #80
KBD85's Avatar
Car: 1985 trans am
last three. ENJOY!!!!!!!!!!
Attached Thumbnails REAR BUMPER SHAVE-z081.jpg   REAR BUMPER SHAVE-z082.jpg   REAR BUMPER SHAVE-z083.jpg
Old Nov 26, 2013 | 07:23 PM
  #81
Project-RS's Avatar
keep up the great work. from a distance it has the flat look of the late 90's+ vette
Old Nov 26, 2013 | 07:24 PM
  #82
RedRokkit's Avatar
Car: 1984 Trans Am, 1986 Fiero SE
Engine: 5.0 H.O., 2.8
Transmission: T5, M4 Muncie
Axle/Gears: 3.73 disc posi, CAVALIER AXLES!!
Dude, stand back and get one of the whole car. Cool project, came out nice
Old Nov 26, 2013 | 07:33 PM
  #83
KBD85's Avatar
Car: 1985 trans am
I will if you would like. There is no front end on it tho. I'm in the process of painting the engine bay. Then putting a new motor in it. So, there isn't much to see from the windshield forward.
Old Nov 26, 2013 | 07:40 PM
  #84
KBD85's Avatar
Car: 1985 trans am
Yes Project-RS.... that is what I was going for. I'm glad you could see that. I must be doing ok then
Thanks guys!!!
Old Nov 26, 2013 | 10:11 PM
  #85
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Looks like a job well done
Old Nov 26, 2013 | 10:15 PM
  #86
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
The base firebird spoilers like in my car are my fav ... I don't like the Wrap arounds
That's the closest shot I have to my spoiler
Old Nov 26, 2013 | 11:04 PM
  #87
KBD85's Avatar
Car: 1985 trans am
1991 sleeper, I think I'll have to try that one. I have three different hatches, all with diff. Fins. One of them is the base fin, maybe simple is what it needs
Old Nov 29, 2013 | 12:22 AM
  #88
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
For the " pontiac " trim out the letters put red plexiglass behind it and use it as a 3rd break light. ..
Old Nov 29, 2013 | 06:46 AM
  #89
robotic_junky's Avatar
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Rear bumper kind of reminded me of the K-1 Evoluzione body kit.
http://www.b-racing.cz/en/evoluzione_en/
Old Nov 29, 2013 | 11:50 AM
  #90
KBD85's Avatar
Car: 1985 trans am
BIG KEG. That is a awesome idea!! Never thought of that
Old Dec 1, 2013 | 08:57 AM
  #91
KBD85's Avatar
Car: 1985 trans am
here is the latest update, and again, this build has been a PAIN IN THE ***! but anyway, its looking good. im almost ready for paint, got it primed and blocked. I have a few touch up areas then im going to paint it and see what it looks like.
Attached Thumbnails REAR BUMPER SHAVE-z084.jpg   REAR BUMPER SHAVE-z85.jpg   REAR BUMPER SHAVE-z86.jpg
  #92
KBD85's Avatar
Car: 1985 trans am
just a few more
Attached Thumbnails REAR BUMPER SHAVE-z87.jpg   REAR BUMPER SHAVE-z88.jpg   REAR BUMPER SHAVE-z89.jpg
Old Dec 1, 2013 | 09:03 AM
  #93
Car: 1991 firebird
Axle/Gears: 4.10
I like it ... I think it will look good when finished ... That spoiler would have to go if it was mine tho
Here is a couple more pics of my spoiler I was talking about ... I still think this is the best looking factory spoiler I've seen on any 3rd gen bird
Old Dec 1, 2013 | 09:09 AM
  #94
KBD85's Avatar
Car: 1985 trans am
Attachment 268379
Attachment 268380
thank you!
yes i think i agree, its just one i have sitting on there at the moment, i have a deck lid with window tinted with the fin like yours on it. I will put it on when i take final pics and see what we got. its actualy the one it came with, so it will even be the same color for the photos. LOVE your wheels BTW!!
Old Dec 1, 2013 | 07:00 PM
  #95
Car: 1991 firebird
Axle/Gears: 4.10
Yea I liked the price too ... OE wheels.com caught em on sale for 358$ a set plus 80$ shipping !
Old Dec 8, 2013 | 05:31 PM
  #96
Mystyk_Wynds's Avatar
Car: 88 gta
Only thing that I could see, is that you lacked the width across the back to make the cut down bumper guard fit.
I would have just removed the rectangle section with the pontiac impression.
Split the bumper in half in the dead center.
Lined up the body lines on one side, along with the back, tacked it up.
Then went to the opposite side did the same thing.
Then made a filler section for in between the two sides on the dead rear, tacked that in.
Then used apoxy to fill in and reform the center section. Larger mounting area for the liscence plate.
Put the pontiac impression back in if desired.
Old Dec 8, 2013 | 06:08 PM
  #97
KBD85's Avatar
Car: 1985 trans am
Yes I did think of that, but there is a height fitting issue also. So I was going to basically do what you said and also horizontally to (cut a plus sign) and that might have been easier looking back. Your right about the license pate box. It would be European sized.. Hehehe.
P.S. I will still paint this so you can all see. It just decided to dump a butt load of snow here, so it's gonna be a bit till I get to it.
Old Dec 15, 2013 | 12:01 PM
  #98
Car: 88 gta
******* it KBD. Get some pvc poles, a plastic tarp, a good space heater, a box fan; assemble a rectangle and have at that painting in the front yard. LMAO
Old Dec 15, 2013 | 02:08 PM
  #99
KBD85's Avatar
Car: 1985 trans am
LMAO!!!! I'm so ready to. I want to see what it will look like painted. I have two weeks off after this coming week. I will paint it then. The 305 is getting taken out at the moment. Going to paint the engine bay your style. Cuz I'm not waiting for spring.
Old Jan 11, 2014 | 02:20 AM
  #100
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
in for an update
