panhard and trailing arms
Old Nov 29, 2001 | 11:45 AM
fourspeed's Avatar
instead of purchasing new aftermarket ones i was wondering if anyone has done the poor mans modification and if they did how it worked out....cutting a piece of metal and welding it in to the open end of each bar the full length so in essence you have a box rod/arm when done.
86 IROC 305 TPI, KYB shocks, poly bushings, alochol/water injection, MSD, K&N, map relocated, Flexalite dual fans, 1.6 rollers, March pulleys, ported plenum, overlays, cat gone and 3 inch flowmaster into 2 2.5pipes, MSD 300+ wires and platinum plugs, 170 thermostat, gutted air box and all free mods, (in storage for 15 years)
Old Nov 29, 2001 | 12:39 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I've done it. There was improvement.
When I lowered my car I changed over to all aftermarket toys.
I think you are on the wrong board.
Old Nov 29, 2001 | 12:56 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
I personally haven't done it, but i would assume it would work pretty well. Try posting this in the suspension board.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Nov 29, 2001 | 05:10 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Competition Engineering sells pre-cut steel boxing plates for the LCA's.Only $20.Seems like that would be easiest, as all you'd have to do is prep the arm,weld them on and stuff some new bushings on 'em.Should be great bang-for-the-buck mod, if you weld them yourself.
-Rich-
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
