Should car covers be tight, or a little loose
Car: 91' Z28
Engine: 355-Supercharged
I just bought a car cover, and i was wondering should the cover be really tight against the car, or should it be a little loose to allow for movement ??? The underside is supposed to be "paint safe" with 3 layers of protection againt the weather. This is the first time my car will be outside for the winter, so im really very protective of it, any witerization tips would be very helpful !!!!!
1991 Z28 Modifications: 17x9.5 Tourque Thrust II's on dunlop sp 5000's, 3" cowl hood, repainted Red/Black racing striped all the way down to GFX, Pro-Kit lowering springs, KYB GR2's, Suspension engenering poly tie rod kit, Autometer dual guage pod with air/fuel and trans temp, Macewen white face layovers, Panasonic DF 88, Reactor 5" Tv, Plastation 2, K&N's, tpis throttle body airfoil, 3" pipes through high flow cats... no muffler, ATI procharger D1SC
Car: 85 Trans Am WS6
Engine: 305HO L69
get one of those car bags. it's like a car cover, but it completely encloses the car, even underneath. i've never tried it, but i heard they're great for keeping the weather out.
87 Camaro LT
bone stock 305 w/ 700r4 0-60: 3 minutes
mods to come:
ground effects
93 camaro seats
99 camaro center console
91 z28 rims
white 145mph iroc gauges
87 Camaro LT
mods to come:
ground effects
93 camaro seats
91 z28 rims
Car: 1985 Trans Am
Axle/Gears: 3.70
Mines pretty tight. As long as you bought I decent cover you shouldn't see any scratches. My car is all black and I haven't seen in scratching and my car spends 90% of it's life under the cover.
1985 ASCD Ram Air Trans Am 350/5spd Pro Action heads, Comp cams XR282, Edelbrock Air Gap, if it can be changed it has Readers Ride at https://www.thirdgen.org/rides/index...ew&rideid=1067
-=ICON Motorsports=-
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think it would depend on what you are doing with it & where you are parking your car.
I prefer a loose cover because it is easier to put on & take off. BUT my car is inside & no-one is ever around it to disturb it but ME.
If your car was outside I would be concerned with the wind blowing sand & dust underneeth which could cause scratches as the cover moved from the wind. But you loose some of the breathing that might occur from having a loose cover.
I'm no expert on covers though...
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
John
G O D BLESS AMERICA
83 Camaro
83 T/A
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
