aftermarket tachs
Old Nov 30, 2001 | 01:27 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
aftermarket tachs
well im getting my msd 6al here this weekend and i hear that you will need to buy a new tach that will work with it. even if that is not the case i do plan on buying a new one, but i was wondering what you guys felt would be considered tasteful and what would be considered tacky? im eventually getting white face gauges for my car, so a white tach might be the way to go. how hard are they as far as install? where should i mount it? i know some people mount it outside in front of the cowl, and my cowl is four inches, but im worried about someone stealing it. well, id like to hear some opinions and see some pics, thanks
1987 LG4 Camaro z28
Mods- 80 series flowmaster, k&n filtercharger, open air element, cat pipe delete, 180* stat, edelbrock performer intake, msd blaster coil, ascd big block hood, panasonic cd player, rockford everything else.
Old Nov 30, 2001 | 04:42 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Your factory tach should work fine. If in the event it doesn't the instructions tell you what you need to do to make it work.
As far as where to put it and it being tacky, that's personal opinion. I found deciding where I wanted it and mounting as being the hardest part. If you can install a stereo you can install the tach, it's pretty basic. Maybe even easier then a stereo b/c there's less wires. Sorry this pic is fuzzy, I just got the digital camera and don't know what I'm doing with it yet. My tach is behind my steering wheel in front of the factory tach(very close to the key and you can't really tilt the wheel up but it doesn't bother me any) The other gauges are under the vents in the triple gauge holder with the angle pods to tilt towards the drivers seat.
Old Dec 1, 2001 | 04:51 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
The factory tach will not work with the MSD. MSD makes a thing that will alow it to work, but if you're getting guages anyway, forget it. All Autometer, and Autoguage(made by Autometer) will work with the MSD. I have mine in the left corner by the pillar. But in a Camaro, you can put it under the center vents. I wish I could.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Dec 1, 2001 | 08:49 AM
toosloz's Avatar
the factory tach will work.....i have a msd6al and it works great....
what you need to do is run a wire to the output on the msd to the brown hook up wire on your hei......its that easy....follow the instructions and you'll be all good in less then an hour...look at my site if you need an idea where to mount it...thats if you dont have a/c
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
14.3@95mph
http://www.geocities.com/toosloz/84camaroz28.html
Old Dec 1, 2001 | 10:59 AM
cvpde37's Avatar
Mine's mounted under the center vents. There are pictures in the sig.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
