Speedometer doesn't work
Old Dec 1, 2001 | 11:50 PM
MotorCityMuscle's Avatar
The speedo in my 83 Trans Am doesn't work. The transmission WAS shot to hell,so I figured maybe the gears were trashed. Now the new tranny has known good gears in it so:
1) if speedo still doesn't work, what do I do?
2) how do I disconnect the speedo cable from the speedometer to remove the entire cluster?
Old Dec 2, 2001 | 09:30 AM
3gc's Avatar
3gc
Car: Z28
It's a pita disconnecting the speedo cable. You have to lay under the dash and with a screw driver push the clip around the cable down and pull on either the cluster (if you have all the scews out) or pull on the cable. Then it should just come out. Took me about an hour to remove the whole cluster for the first time a couple weeks ago.
Old Dec 2, 2001 | 03:11 PM
toosloz's Avatar
if you remove the dash pad...its so much easier to pull the gauge cluster
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
14.3@95mph
http://www.geocities.com/toosloz/84camaroz28.html
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Wade787b
Sep 29, 2015 01:15 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
