Rear Cargo Area Panel Rattling Fixes?
Old Dec 2, 2001 | 01:04 AM
Night Hawk's Avatar
The rear plastic panels in my 88 GTA rattle like crazy among many other mystery rattles in the rear cargo area. How many of you also have this problem and how do you solve them?
1988 L98 GTA
3.73 Posi
Polished & Ported Plenum, JET AFPR
Free Mods, Cold air Intake
Subframe Connectors, Strut Tower Brace, Lowered,
SLP 1 3/4" Stainless Headers, Edelbrock Catback, High Flow Converter,
Crane Fireball Ignition,
BF Goodrich G-Force P255/50R16's
Old Dec 2, 2001 | 09:24 AM
3gc's Avatar
3gc
Car: Z28
I'd just take the panels out make sure no clips are missing and put it back together.
Old Dec 2, 2001 | 03:32 PM
Drew's Avatar
All the threaded plastic inserts that the large trim screws and trim pins push into can be replaced rather easily. Typically they're either missing or badly damaged. Both the inserts and trim screws are available from the dealers for $.50-1 each.
Old Dec 2, 2001 | 07:32 PM
Night Hawk's Avatar
Really! Thanks, I never knew the dealers would bother with such a small cheap peice. This is really going to help because the white plastic peices that the trim screws into are badly damaged and I can't torque the plastic trim screws down worth beans, thanks!
1988 L98 GTA
3.73 Posi
Old Dec 2, 2001 | 09:13 PM
un4givin89's Avatar
GEt some cheap *** foam like the kind for your bed or pillows and stuff it in between thsoe panels as well. I did this to remove hatch noise.
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
Old Dec 2, 2001 | 10:03 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes replace the plastic mounts for the large plastic screws fro the HELP section of the auto parts stores. Also use Goop asdehive on the panels to keep them from rattling. Apply it both to the back side and the interference points. I've used it on the center console and air vents (in the door B-pillar). Do a knuckle rap test on the panels to find the rattles. I also used Dynomat on the inside of the metal panels.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Dec 2, 2001 | 11:11 PM
jobryan26's Avatar
Buy some one-sided sticky foam weather stripping. Like what they include with some speakers. Works great.
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
z28addict8490
Aug 7, 2015 08:48 PM
