headliner material
headliner material
hey guys,
I was wondering has anyone ever used anything besides the normal feltlike material for a headliner, my fiancee's car has a sort of plastic headliner. it doesn't look quite as nice but it's really durable. could I used a nylon or a vinyl, or is it easier just to use the felt.
neko
'87 trans am
car in the making
angelfire.com/fl2/neko
neko
'87 trans am
car in the making
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Use the Felt, you can buy it at JoAnns Fabrics. If they have different brands look for the stretchiest you can find if you have T-tops. If you have a hard top, most any of it should work fine... The vynal is kind of streatchy, but it does not streth enough for a headliner ESPECIALLY if you have T-tops.
To get the old stuff off, once the headliner is removed, & the old material is off, take a wire brush & remove the excess foam left behind, make it really clean, then take some spray adhesive & stick the new stuff on...
3M makes a couple kinds, 77 & 90 come to mind they work pretty well. the 77 is designed to be moved & adjusted, but the 90 is more of a once you place it, thats all there is.
I personally like the headliner adhesive spray, it comes in a Gold can, and can sometimed acquired thru fabric or interior shops.
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
G O D BLESS AMERICA
83 Camaro
83 T/A
MrPackstin
Oct 25, 2017 08:09 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
