Pop-up headlights!!!
Old Dec 4, 2001 | 08:16 PM
FstBrd6point3's Avatar
I have an 87 Formula, and I am having problems with my passenger side flip up headlight. Sometimes it goes up, sometimes not, sometime it goes half way then stalls then goes, somtimes it doesn't go bad down, it is very unpredictble. When you tank near the light, it sounds like the gears may not be catching all the time. Can this be fixed? or do I need a new motor set-up? If I do need a new one, am I better off to buy the entire thing or just the motor?? anyone withy any experience as far as price goes?? andy help will be great, thanks
1987 Pontiac Firebird Formula 350
1 of 2,384 made, Black with Silver decals
350 TPI
700R-4 Tranny with TCI shift kit and Corvette servo with TV boost sleeve
TCI saturday night special 2200-2500 stall converter
WS6 supsension
SLP headers with full 3" exhaust exiting through an SLP dual 2.5" tip muffler
SLP airfoil
180 degree thermostat
hypertech "performance" chip
3.73 rear
Viper talkin alarm with remote start
My 383 is in the process of being built right now, hopefully to make it's debut by middle December. . . many more mods to come in the summer. . maybe some experimentations with juice. . have some track times my independence day.
Old Dec 4, 2001 | 08:40 PM
ddsmith's Avatar
Do a search on headlight and you'll find plenty of informative post. If the headlight motors are running but the headlight doors are not moving then you need to remove the headlight assembly from the car and repair the gear drive unit. This is really no big task. I did it on my 87 Formula and it was pretty easy. You'll find links to step by step instructions for this when you do the search. The cost was six steel ball bearings from the hardware store. A couple of bucks maybe. I would do this even if I thought it was something else. If you fix this it will not come back to trouble you in the future. The other possibility is headlight module/light switch problem. You'll find a post today that explains the function of this stuff. No need to rewrite it. Good luck.
1987 Formula 305,1971 Corvette 454, 1966 Chevy C30 Flatbed Dump, 1989 Pontiac 6000 STE AWD.
Old Dec 5, 2001 | 06:25 AM
ddsmith's Avatar
I found a link for you that I used to repair my headlights. Steve has alot of other good info also. http://www.transamtemple.com/modific...ght_repair.htm
Old Dec 5, 2001 | 08:03 AM
scauffiel's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ddsmith:
</font>
<elvis voice> Well, thankya, thankyaverramuch.</elvis voice>
Steve
Steve's Trans Am Temple
Old Dec 5, 2001 | 10:28 AM
I read yer site steve, thanks, I though this was gunna be a big ordeal to fix, but it looks like I can do it rather quickly and easily, thanks for the help
350 TPI
WS6 supsension
SLP airfoil
3.73 rear
Old Dec 7, 2001 | 01:06 AM
formula88bird's Avatar
I just fixed and installed my passanger side headlight moter. It only took $0.90 and a half hour. A BIG thanks goes to steve for all the great info on his site, and to everyone at Thirdgen.org.
305TBI(LO3)
K&N filter
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
