dash questions
Old Dec 7, 2001 | 05:32 PM
NotDadsW41's Avatar
dash questions
Hi Guys,
New to this part of the board. I usually hit just the TBI board. But now I'm ventruing into uncharted waters I think. I have two late 80's model Caprices and I;m thinking about swapping the dash from a 3rdgen into one and I have several questions regarding the dashes.
First off I need some measurements if possible. Overall width and the height from the steering column to the top of the dash.
Second - which years of 3rdgens came with a cable driven speedo and which were run by a VSS?
That should do to get me started!!
Thanks!
Cecil
Old Dec 8, 2001 | 12:02 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
82-89 camaros were cable driven, 90-92 were vss
87 Camaro LT
bone stock lg4 w/ 700r4
1/4 mile: 35 seconds @ 50mph (or so it feels like it)
mods:
ground effects (in progress)
93 camaro seats (installed)
99 camaro center console (in progress)
85-87 iroc or 91-92 z28 rims (91-92 installed)
white 145mph iroc gauges (in progress)
Old Dec 8, 2001 | 12:31 PM
NotDadsW41's Avatar
Thanks for the reply. Do you know if they used a VSS to supply a speed to the ECm at somepoint in there??
Old Dec 9, 2001 | 07:37 PM
Jza's Avatar
Jza
The mechanical speedos have a "mechanical" VSS mounted behind the speedometer and attached to the speedometer cable. The raw signal goes through a buffer which is then distributed to the ECM and cruise control.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
redmaroz
Aug 16, 2015 11:40 PM
Vintageracer
Aug 11, 2015 08:13 PM
