floor pans
Old Jan 16, 2014 | 02:49 PM
codyscamaroz28's Avatar
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
floor pans
i pulled my interior the other day, going all balck interior on my 82 z. I discovered some rust on my floors pans few little rust holes on both front pans.What is the best was to fix this? Here is some pics, i hit em with a wire wheel. There is a few holes on each side., will some rustoleum work for this?
driver side front floor pan
2e3dd65e-4381-4525-b9fe-df16b5c89491_zpscba9ae27.jpg?t=1389904957
passenger side front.
2129c3c0-59b9-456d-b0ba-b0f57487fc7e_zpsf8d541d6.jpg?t=1389905043
Old Jan 16, 2014 | 04:49 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: floor pans
I'd go with POR15 personally. Heard nothing but great things about it.
http://search.eastwood.com/search?w=por15
Old Jan 16, 2014 | 05:12 PM
Re: floor pans
yes ive heard good things about that too. is this stuff good the under body also?
Old Jan 16, 2014 | 08:34 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: floor pans
por15 does its job but frist you need to repair the hole if you have a welder or know someone that has one that would be the best way to fix it or you can use fiberglass and top coat with por15
Old Jan 16, 2014 | 08:54 PM
Re: floor pans
ive never did any body work really. id like to go the welding route, my dad has stick welder. how to go about fixing these holes. any tips? also this fiberglass how good does that work?
Old Jan 16, 2014 | 08:59 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: floor pans
stick welder will not work. Your best bet without welding would be to buy the POR15 floor repair kit.
Old Jan 16, 2014 | 09:03 PM
Engine: LQ4 ls 6.0
Re: floor pans
fiberglass is not the best way to go but if you grind around to hole and apply some kitty hair that is fiberglass grind it down smooth and then you can apply a coat of truck bed linning or por15 you will need to seal it on top and bottom if you did it this way it will last for a long time since its a small area
Old Jan 16, 2014 | 09:07 PM
Re: floor pans
where can i get some of this kitty hair. i just ordered some POR15 but not the floor repair kit. do i need to just get some fiberglass, or do i need some of that putty also?
Old Jan 16, 2014 | 09:12 PM
Engine: LQ4 ls 6.0
Re: floor pans
just the por15 then you can go to oreillys and pick up a quart of evercoat kitty hair you can also get it at auto paint store
Old Jan 16, 2014 | 09:16 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: floor pans
Old Jan 16, 2014 | 09:18 PM
Re: floor pans
thanks for the info man, i hated finding the rust. im glad i caught it now though.
Old Jan 16, 2014 | 09:24 PM
tgarcia76513's Avatar
Re: floor pans
Any automotive paint supply will have both the kitty hair and a por type product. Most likley wont be the brands from the eastwood site but no waiting or shipping cost. Make sure you take care of the rust first so it won't continue to rust under your repair. They also make tiger hair for the great big holes. As always read the labels for instructions. This could save you some headaches down the road. Good luck.
Old Jan 17, 2014 | 08:12 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: floor pans
Cut some small sheet metal squares, big enough to cover the holes and have some around all sides. Clean all surfaces (sounds like you already did that). Coat the side of the patch that is going to contact the floor pan with a rubberized undercoating, stick in place, and pop rivet to the floor (or weld, if you have one of those handy. Follow up by spraying some undercoating on the the underside of the floor pan.
Worked for me, but to each his own, mine is no show car or anything.
Old Jan 17, 2014 | 02:14 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Re: floor pans
Mine were much worse and I cut out and welded in all (well most...) the patches and then use chassis saver (por15 like stuff). I then top coated that with truck bed liner.
I say most of the patches. After welding was done and while prepping to do the chassis saver I found a couple more sub-dime sized holes where the surrounding metal was still thick. Instead of breaking out the welder again I made up a steel patch, prepped it and chassis saverred it over the hole (use the chassis saver as a glue). No way those small patches will come off, does not matter how much I pry!
I would not use this technique for anything structural but it worked great for a small hole with good metal around it. I would expect the same results for por15.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LC2 TECH
Oct 13, 2015 11:53 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
