Doors
Old Dec 8, 2001 | 04:23 PM
Trent257's Avatar
Doors
will any third gen doors fit my car???
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
Edelbrock Performer manifold/small block 400 rebuild going in next summer
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Dec 8, 2001 | 04:48 PM
CD MaroMan 91's Avatar
Yes... any Firebird/Camaro 82-92 Door.. Will fit any OTHER Firebird/Camaro 82-92... I just did this to my car haha it looks funny tho cuz it's red and my car is blue but I'm about to get it painted... you will either have to fill in the old ground effects holes or drill new ones if your ground effects don't fit.
Before Wreck...
After Wreck...
1990 Firebird I Bought For Parts...
My Camaro RS With Firebird Door
Hope this helps.
'91 Camaro RS 3.1L V6
4th Gen Seats, Sony Xplod CD Player, DJ Sexay's Kicks Panels with a Polk Audio 6½" Comp Set, 2 RF Punch 12's, RF Punch Amp 100.2, Coustic 360W Amp.
Soon to come, New Rims, New Rear Tires, Paint Job, Interior Color Change.
http://www.geocities.com/adidaspredator21/index.html
**BUT FIRST... gotta fix this... stupid people..**
Old Dec 8, 2001 | 05:03 PM
Trent257's Avatar
ok thanks, hat parts car looks just like my friends
Trent
---Car---
---Stero---
profile cl640 110x4
Old Dec 8, 2001 | 05:34 PM
88greyiroc's Avatar
did you have to take your fender off to change the door?just curiousm i have to change my hinges and crap and i was wondering how you took the door off?
Old Dec 8, 2001 | 06:53 PM
I didn't take the fender off... prolly should have... I have small hands so me and my dad held the door up and kinda opened the door so I stuck my hand in between the fender and it was hard as anything 2 screw the bolts. All you do though is disconnect ur battery so it doesn't die with having the door off. Then you just open the door... take off ur kick panel to get the 3 bolts at the bottom. Then use wrenches and sockets 2 get the bolts off the top and bottom hinges... then the door will come off. It's good to have someone help you as the doors are heavy and will bend the hinges if you don't have the door propped on blocks or something when one hinge is undone.
**Got the new door on... gettin car painted in about a month or two...**
Old Dec 9, 2001 | 10:44 AM
88greyiroc's Avatar
how can i tell if the bottom part of my door is bad or the top my right hand door sags so bad it hitas the ground effects and my left one is so bad when i hit a bunch it makes a racket like it goes up and down with the bump but i can open the doors and they feel solid when i lift up on them?
1988 Iroc-z (Gun MetaL)
350TPI (38K MILES)
700r4 stage 2 shiftkit
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 10, 2001 | 05:35 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Open the door only slightly, 3" or so. Then grasp the bottom rear of the door. Lift up on the door. If the hinges are worn out,(as they usually are)then you will see it. The LOWER hinge can be repaired with about $4.00 worth of parts. The only way to fix the UPPER hinge is to buy a new GM hinge, and then cut the old one off the door, as it is welded to the door. Or you can get an UPPER hinge repair kit from www.3rdgensolutions.com It takes about 2 hours to install, and you do not need to remove the door from the car.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
kkirch15
Sep 30, 2015 04:44 PM
