highbeam switch, gas guage
Old Dec 8, 2001 | 01:52 PM
elizabeth's Avatar
The swith for my highbeams only wroks once in a great while. Could someone please tell me where it is located and an general idea how to repair it. Thanks
Also my gas guage will read 1/2 just forever, I can be sitting on fumes and it's still 1/2 tank. Then it drops like a rock past empty. could the float be sticking? can I repair it myself? I have been watching the mileage right now and when it hits around 330 I know I better find a station! Thanks
Old Dec 8, 2001 | 01:56 PM
toosloz's Avatar
it is located on your steering column under your dash...the part cost about $26 from gm new..i had to change mine due to not having brights at all...also, when you fix it, make sure you adjust it before you tighten it down
Old Dec 8, 2001 | 02:31 PM
nagga's Avatar
if its not the part hes talkin about it could be the arm itself, which is spendy and i dont think u could change it your self, unless u have a steering wheel puller, the arm thing is like $145!!! and i need one dammit
Old Dec 8, 2001 | 04:16 PM
elizabeth's Avatar
I sure hopes it's the arm!!! How can I tell? without purchsing the part first?
Old Dec 8, 2001 | 04:50 PM
toosloz's Avatar
the arm?....the piece with wipers/cruise control/???
if you pull back on your turn signal arm and it "clicks" and nothing happens...its your dimmer switch
84z28HO
355 9:5:1
open element/k&n
m5/hurst billet plus shifter
polished hurst "t" handle and shifter arm
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
msd6al/blaster 2 coil
msd hei dust cap
accel 8mm wires
adjustable thermostat switch
180 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror w/ maplights
"wonderbar"
4th gen z28 tips
14.3@95mph
soon to come....hooker catback,slp headers, performer rpm intake and 750 carb and eibach springs/kyb struts
http://www.geocities.com/toosloz/84camaroz28.html
Old Dec 8, 2001 | 06:56 PM
elizabeth's Avatar
Thank you so much!!! the arm doesn't make that click any more so now I can repair it myself.
Elizabeth
Old Dec 8, 2001 | 08:22 PM
toosloz's Avatar
just make sure you adjust this swith before you tighten the dimmer switch or you'll be in the cramped spot it is located in for a bit of time...there is a rod that runs down the column and goes into this little hole, align it and use trial and error and you should able to fix it in about 1 hour or so
Old Dec 9, 2001 | 05:35 AM
elizabeth's Avatar
being able to fix my higbeams will really be a lifesaver on these country roads!!! thank you.
Old Dec 9, 2001 | 06:08 AM
toosloz's Avatar
np...watch out for deer!
Old Dec 9, 2001 | 10:44 AM
Brent Swan's Avatar
How quickly people forget about past friends ..anyways,sounds like the cruise/wiper arm.I just recently bought my 89 RS and I know for a fact it needs a new one because I do not have high beams,plus the arm moves very freely.As far as your gas gauge,sounds like your fuel level sender or possibly the float "sticking" Hope this helps
Brent
Toys currently owned:
-91 MPFI Firebird
-97 Grand-Am GT
-96 Extreme Sonoma
-91 Suzuki GS500E
-89 IROCZ Camaro(under construction)
-89 RS Camaro(under construction)
Old Dec 9, 2001 | 12:41 PM
nativ's Avatar
there is a tech article here on how to install a floor dimmer. I did it in about 1/2 hr. it bypasses the column stuff all together and works great. no more high beam colum problems. sorry cant remember where article is.
Old Dec 10, 2001 | 11:22 AM
Drew's Avatar
Do this quick test before you take anything apart... Grab the top and bottom of the steering wheel and pull at the top then the bottom, if the wheel tilts and then pops back to normal when you release it then your steering column is loose. Tilt columns have a knuckle in the middle with pressed in pins that allow the assembly to pivot. On my Formula one of these pins backed out and caused the column to not hold its normal length. The end result was that the rod wouldn't push far enough on the switch to activate the high beams. The loose steering column problem happens on about 90% of GM cars, including Fbodies. If nothing else its worth looking into before spending money on parts.
As for the multifunction lever being the culprit, thats virtually impossible since it just goes into a socket that pulls or pushes a rod connected to the high beam switch down on the column. Also the multi function lever is EASY to replace, grab hold of it firmly and pull. If you have cruise control its just a matter of disconnecting the wire before pulling the lever out. Installing a new lever is the reverse, push it in.
On to the gas guage. This is rather typical of thirdgens. Don't ask why, but for whatever design flawed reason, the gas guage needle doesnt move in a linear fashion. The first 1/2 tank will last roughly 2-3 times longer than the last 1/2. It gets exponentially worse the lower it gets. The best advice I can give is to keep it above 1/4 tank at all times, don't go below 1/2 tank on road trips. Calling AAA for someone to bring you gas, or trying to push a 3500lb car to the next gas station isn't worth it.
Drew
predatorman@hotmail.com
83 Camaro 5.0L *1995-98*
87 Iroc 5.7L
91 Formula 5.7L 14.3@98mph
91 RS Convertible 5.0L
91 Firebird 3.1L 17.00@82mph *Gtech*
92 S10 2.8L
98 Grand Am GT 3100
Parts for sale
Old Dec 11, 2001 | 05:12 PM
toosloz's Avatar
too late....she smucked a deer
84z28HO
355/5spd/3.42 gears
lots of mods!!!!....need more!
14.3@95mph
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
