Formula Hood w/ Aero Package pic needed
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
anyone have a pic of there firebird with the aero package and a formula hood?
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Formula Hood w/ Aero Package pic needed
Not the best representation but here is my 92 with an early ta hood.
Engine: 5.7 L98
im torn between trans am hood and formula hood. what i find crazy is how hard it is to actually find one... at least in good shape...
Axle/Gears: 9-bolt/3.45
There's a TGO member named Cadillac, and he has a 'vert like yours with a Formula hood. Great looking car. I think you'll like it.
Engine: 305, 355
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
U should paint the top of ur headlights black for the time being ...jus say in
91' firebird .. 305 TBI .030 over , balanced bottom end , speed pro hyper flattops , 10.6:1 CR , all ARP rod bolts and main studs , melling HV oil pump , trick flow super 23 175cc heads, Howards HR 214/218@.050 .488/.495 lift on 114 LSA , full roller 1.6 RR = .520/.528 lift , summit dual plane intake port matched , shorty headers into 2.5" Y w full 3" flow master system and 3" cutout in front of axle , msd billet dizzy, 620cfm TBI , custom CAI , tubular adjustabke LCA pan hard , umi torque arm wonder bar , BMR trans cross member , COMP engineering SFC's, disc rear w 4.10's, drilled an slotted rotors, EBL flash , VRFPR, WBO2,
Car: 1991 firebird
Axle/Gears: 4.10
I think I actually like the base birds without ground effects ... I don't really care for the side skirts ... I really wish I would just found a stock ta or formula hood or even a RA 1 instead of buying this piece of **** RA 2
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
