how to repair front valence on front bumper
Old Mar 20, 2014 | 09:18 AM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
I am repainting my car and want to do it right this time, and my front bumper needs some attention, especially the valence. I'm talking about the "ground effect", very lowest part on the bumper.
I was talking to a body guy and he said it is made out of a plastic/rubber composite, which allows it to flex. It seems like if it is meant to flex then bondo/fiber glass would crack under the repeated stress of flexing. I know spot puddy/glazing is soft and is going to allow some flex; to me it seems like it would be better to use than bondo.of course of its softer maybe that means it will crack even easier. Other downside is it can't be put on very thick.
Maybe I could somehow reinforce the valence so it doesn't flex, or at least much less, then use filler?
I appreciate the help!
Old Mar 20, 2014 | 09:20 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: how to repair front valence on front bumper
http://www.autobodytoolmart.com/imag...422-bumper.gif
Old Mar 20, 2014 | 09:26 AM
Yenipenny's Avatar
Car: 92 RS Heritage
Don't even think of using glazing putty or body filler. Use a flexible repair kit such as the one linked above. There are other brands available also. I use 3M. None of them are cheap, but they are necessary.
1992 Trans Am
May 10, 2023 07:19 PM
zayne0
Aug 24, 2015 07:22 PM
mikey8494
Aug 22, 2015 07:57 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
