using fiberglass cloth in the spare tire well?
Old Mar 22, 2014 | 09:40 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Hey guys. I'm getting around to doing some body work and one of the issues with rust my car has and honestly the only spot is that the spare tire area, at the bottom of the arch has fallen through. Well can I use the fiberglass cloth and resin to did that?
Old Mar 22, 2014 | 10:16 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Don't think I would do that..it can still collect moisture from underneath..get some sheet metal and seam sealer..seal up both sides real good and paint it..or go through the task of cutting and welding it in.. But for that area that no one sees anyway..I would just do the seam sealer..
Old Mar 22, 2014 | 10:34 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: using fiberglass cloth in the spare tire well?
Not a good idea, it will crack later on and you will be back to where you started. Your best bet is to weld in new metal but if you do not want to do that you can use 3m panel bond to put new metal in. Can you post a picture of the damage, we can help you better if we get an idea of how bad the rust is.
Old Mar 23, 2014 | 09:01 AM
Engine: L31 350
yeah no problem. Next time I'm in The garage I'll try and snap a picture. Its not the that bad but enough to let in noise and exhaust fumes from time to time.
Old Mar 23, 2014 | 09:43 AM
Twin_Turbo's Avatar
dioadir
Old Mar 24, 2014 | 06:37 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
You can use fiberglass cloth, but don't use PE resin, use POR 15.
Strip all the paint ant rust from surrounding metal. Paint on POR 15, inside and out. Lay in cloth, at least 6oz , wet out cloth with POR 15, do second layer when almost cured (follow directions). This is the ideal type of repair for por15 and fiberglass.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
