Replacing lower Door Skin.
Old Mar 23, 2014 | 12:48 PM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Hi,
When replacing the lower door skin. Would it be better to apply seam sealer sealer to each side of the door bottom before placing the door skin over it and using hammer and dolly. Was thinking of doing this and once door skin was on just smooth the seam sealer but am worried that it will take me too long to put on door skin and seam sealer will have hardened before I am finished. Just wondering what the procedure is or what other people do.
Thanks.
Old Mar 23, 2014 | 01:12 PM
Joe Tag's Avatar
Re: Replacing lower Door Skin.
I saw a thread the other day where someone had used 3M seam sealer and it hadn't cured for about 3 weeks. I think you're safe on the time factor. The mess it would make might be another story.
Old Mar 23, 2014 | 01:26 PM
gholian's Avatar
Engine: 2.8 V6
Yes, Guess it would end up pretty messy alright. Will have to think about it.
Thanks.
Old Mar 23, 2014 | 09:00 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
If you think that may be a problem then you could install the panel then just seam seal around the edges
Old Apr 2, 2014 | 09:44 PM
TEEZER TA's Avatar
Car: 1986 Trans Am
Engine: 383 Stroker
Transmission: LT1 T-56
Use 3M Panel Bond, It sticks to bare metal, corrosion resistant, and a long work time. That is what body shops use when replacing panels.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BlackTopKing
Aug 19, 2015 12:13 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
