How to remove sounded deadener and POR15...
Old Mar 28, 2014 | 11:51 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I am building my car from the ground up.... again.
I used a lot of Dynamat and FatMat on the interior, as well as POR-15 on the undrerside. Used one coat in the inside as well.
I have every last bolt out of the car, minus the hatch, motor and tranny left to go.
Once those are out I want to start to strip the car down to metal to fix all the patchy work I did at a teenager (I am 30 now). I want to smooth the firewall and wheels wells. I also want to remake the rust patch pannels I had made before.
But to get to all these things I need to remove the sound deadener.
What is the best way to do this? Heat gun, time and maybe some sort of miniral spirits after?
Any suggestions?
Old Mar 30, 2014 | 12:04 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: How to remove sounded deadener and POR15...
I have never used it but this is what POR 15 recommends.
http://www.por15.com/POR-Strip_p_20.html
Old Mar 31, 2014 | 12:25 AM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Try using dry ice and a hammer, Dump the dry ice on the floor board then start hitting the floor with the hammer, not hard enough to dent the floor also a chisel once the sound deadener start to chip up you can get under it with the chisel and hit on it to pop it loose.
Frozer!!!
Jan 19, 2024 04:55 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
