Loose bumper cover
Old Jun 27, 2014 | 10:32 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Loose bumper cover
The rear bumper cover on my T/A is so loose you can hear it rattle when driving. The plastic retainer pins do not hold it tight against the impact bar so it can pull away from the crush pad. Any way to snug it up? Tried a search, but didn't find an answer here.
Old Jun 27, 2014 | 11:40 PM
Joe Tag's Avatar
Re: Loose bumper cover
You sure the impact bar isn't rotted away? Only clips I've seen that wouldn't hold were in rusty holes.
Old Jun 28, 2014 | 05:46 AM
Hal87's Avatar
Yup, had to replace the impact bar 2 years ago. Bar is good, crush pad is good. Wonder if some shorter retainer pins would hold the cover tighter to the bar and not slide. The holes in the cover are larger than the pins, but not worn, same as in other covers I have.
Old Jun 29, 2014 | 07:18 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
What about the brackets at the sides? That's really what holding the cover in place. Sounds like you are missing them.
Old Jun 29, 2014 | 09:24 AM
Hal87's Avatar
Nope brackets are there and tight. It's the slop of the retainers holding the cover. Took some scraps of Dura-mat and made washers for between the impact bar and the cover. Tightened things right up! Thanks for the suggestion guys.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
SG91camaro
Sep 5, 2015 10:27 PM
