Aftermarket T-Tops
Old Jul 26, 2014 | 08:51 PM
MC87SS's Avatar
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
Aftermarket T-Tops
I picked up a set of T-Tops that are supposed to be for an F-body but they didn't fit my 86. I had put them up on a shelf in the garage and forgot about them until i stumbled on them today.
I think i read somewhere there was aftermarket T-Tops put in the 3rd gens, cars and concepts maybe?
Does anyone have any info on these?
Anyway to tell for sure?
What are they worth?
I can post some pictures tomorrow.
Old Jul 26, 2014 | 09:01 PM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
Re: Aftermarket T-Tops
Car and concepts did make t-tops for the f-body among other cars
so it's possible that's what your set is
here are some pics of C&C t-tops from an 86 that i parted out for you to compare to
you can see the C&C logo on the outer rear corners
in the last pic you can see that the distance from the windshield to the t-tops is larger since the topps are a little smaller than factory
Attached Thumbnails Aftermarket T-Tops-dscn3640.jpg   Aftermarket T-Tops-dscn3641.jpg   Aftermarket T-Tops-dscn3484.jpg
Old Jul 26, 2014 | 11:59 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
There's several threads posted here.Not as common as OEMs t-tops, but worth about the same.Are they the vent type or like the ones in the pics above.
Old Jul 28, 2014 | 01:16 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
There are also early and late factory tops. The early have arms that swing up and the later ones have pins that slide out.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
