Door Hinge Bushing and Pin replacement
Old Aug 15, 2014 | 12:36 PM
RJMcEachern's Avatar
Car: 87 GTA, 91 Nissan 300ZX 2+2
Engine: 5.7L, 6 banger NA
Transmission: 700R4, Auto
Axle/Gears: 3.27 Posi, no idea
I am in the process of replacing my 87 GTA rusted passenger door with a door from an 86 Firebird. I got the old hinges off, sanded, sealed, primered and painted. I ordered a set of the Dorman replacements from the local mega auto store (Oreilly's) and it appears the sizes are incorrect. I did verify online that this is the set that comes up for the door on an 87 but wondering if it is different for and 86 Firebird?
Here is a link to the part I ordered:
http://www.oreillyauto.com/site/c/de...or+hinge+parts
Any help is greatly appreciated
RJMcEachern
EDIT: Oreilly shows same part for an 86 but it is clearly too large for the lower bushing
Old Aug 15, 2014 | 12:42 PM
Joe Tag's Avatar
Re: Door Hinge Bushing and Pin replacement
All 82 - 92 door hinges are the same, birds and maros. Are the bushings too small? Extremely worn hinges sometimes are wallowed out from leaving them go for a long time.
Old Aug 15, 2014 | 12:44 PM
actually the bushings are too big, the uppers look like they might press in but the lowers are way too big, would have to drill the hinge and then the amount of metal left would be sketchy at best.
RJMcEachern
Old Aug 15, 2014 | 12:50 PM
Joe Tag's Avatar
They are splined for a press fit, but you shouldn't have to drill for them. May be the wrong bushings. They do sell them in the help section at any parts store. No consolation on your problem though.
Old Aug 15, 2014 | 12:52 PM
yea i think the one with the pins is ok, just need to press it in, which I can do, the one with the smaller shoulder bolt I don't see how, I'll try to get a pic of it
RJMcEachern
Old Aug 15, 2014 | 01:51 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
RJMcEachern
dude "lonsal" is the one you should buy parts from. top down solutions, is the ONLY game in town. first rate parts and service. need I say more?
Old Aug 15, 2014 | 02:05 PM
i did do a search first and found TDS used to sell these parts, however when I check TDS website today those parts apparently are no longer available?
I agree with you on TDS, if I can get it there from him I go there first...
RJMcEachern
Old Aug 15, 2014 | 03:35 PM
Joe Tag's Avatar
Maybe you misspoke or I am misunderstanding you here. The pin goes on the lower hinge. The two bolts go on the upper.
Old Aug 15, 2014 | 05:11 PM
Car: 86 IROC
Engine: 5.0 TPI
RJMcEachern
WHAT!? lonsal doesent sell the hinge parts anymore. DAMN
Old Aug 15, 2014 | 05:37 PM
i feel like such an azzhat
so in the end the bushings worked!
I was trying to put the bushings in the correct location, but backwards, so I was trying to install them in the hinges on the that I took off, the bottom ones install in the hinge I took off and the bigger ones install in the door upper with the shoulder bolts. it is all together and lubed up so all good, now to transfer the door parts from the rusty door.
Thanks everyone for the replies!
RJMcEachern
Old Aug 15, 2014 | 05:38 PM
if he does I couldnt find them, maybe he will respond to this thread if he does still.
EDIT: oreilly does and the link is above, only 10 bucks each door
RJMcEachern
Old Aug 15, 2014 | 10:07 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
Transmission: Th700R4
Axle/Gears: 3.27, 9 bolt Borg-Warner
I used those hinge kits and it worked out just fine for me. It fixed my driver door and now it close just fine
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
NBrehm
Aug 5, 2015 07:57 PM
