Will I run into any issues trying to use '87 or 88' Camaro body parts on my '92 RS?
Old Oct 11, 2014 | 01:43 AM
mr_william's Avatar
Car: 1992 Camaro RS
I fellow I work with is parting out his car. It's either an 87 or or 88... I don't remember. As far as I know it's just the base model v8 and 5 speed. The only body parts I really need off his car is the front bumper cover assembly (including the ground effects) and the little trim pieces (ground effects?) that go along the bottom of the doors.
I haven't seen his car in a while so I don't quite recall how similar his and mine are.
Old Oct 12, 2014 | 08:59 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Will I run into any issues trying to use '87 or 88' Camaro body parts on my '92 R
The only fitment issue you'll have is that the 91-92 chin spoiler clips in a vertical slit in the fenders while the earlier (85-90) chin spoilers bolt on in 3 holes. If you are changing the ground effects I would change all or none. The 91-92 and 85-90 are two different styles and would look better all together rather than mixed and matched.
Old Oct 12, 2014 | 09:26 PM
mr_william's Avatar
Car: 1992 Camaro RS
Would you happen to know if the 91-92 chin spoiler will fit on the older bumper? Would I have any problems trying to go that route?
Old Oct 12, 2014 | 10:15 PM
Eric-86sc's Avatar
Engine: 305, 355
The 91-92 chin spoiler will bolt right to the bumper cover. The only difference is the fender mounting everything else is the same.
Old Oct 12, 2014 | 11:02 PM
mr_william's Avatar
Car: 1992 Camaro RS
Awesome. Thank you.
Do you know if I'd be able to use the plastic trim at the bottom of the doors?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
1nastygta
Aug 8, 2015 07:38 PM
