door swap
Old Oct 15, 2014 | 07:10 AM
Dombant's Avatar
door swap
My 91 Camaro's drivers side door has a dent. It has a manual lock and crank window. I found a 92 Firebird door that has pw & pl. Can I use the Bird door on my Camaro, and if so is it a lot of work swapping the crank window?
Thank you
Old Oct 15, 2014 | 08:53 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: door swap
You could use the door just look at any trim pieces that need to match. It would be a fair amount of work to swap the power/manual stuff over. Have you thought of keeping the power and getting the other door and adding the rest for power locks/windows?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
