One headlight goes up faster than the other
Old Oct 21, 2014 | 06:28 PM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
I noticed today that my right headlight is starting to go up a little slower than the left one, but they go down completely in sync. Both motors were replaced three years ago. I'm hoping nothing serious is wrong.
Would lubrication solve it? If so, I assume WD-40 would be the way to go. Where should I apply it?
If I can't get away with it that easily, are there separate gears for raising and lowering the headlights?
If you can't tell, I'm a bit of a noob, so you'll have to talk to me like I'm a six year old.
Thank you!
Old Oct 22, 2014 | 10:40 AM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
Re: One headlight goes up faster than the other
If you use them a lot, you may need a rebuild kit. Were they new or remanufactured?
Old Oct 22, 2014 | 12:18 PM
mav75's Avatar
Car: '89 Trans Am
They're new. Too soon to be going out, IMO.
Old Oct 22, 2014 | 01:12 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You prob. have bad bushings or the motor gear is stripped.
topdownsolutions has rebuild kits and parts you may need
http://www.top-downsolutions.com/Bod...-firebirdfiero
Old Oct 22, 2014 | 04:06 PM
mav75's Avatar
Car: '89 Trans Am
It's weird though … if I were losing bushings or a gear, wouldn't the right one go down more slowly than the left one instead of in sync with it?
Old Oct 22, 2014 | 04:58 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
sub'd. Having the exact same issue.
Old Oct 22, 2014 | 05:12 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
I have the same issue with OEM motors although one is original that came with the car and other is out of an 88' with thinking of swapping out the pair with another set I have but in my opinion i'd think the slower one is going bad sooner then later.
Old Oct 22, 2014 | 05:39 PM
mav75's Avatar
Car: '89 Trans Am
I agree with you, although I'm trying to avoid the inevitable! LOL
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
