tiny holes in trunk
Car: 1982 trans am
Engine: 4bbl carb 305 v8
Transmission: 3 auto
tiny holes in trunk
I have spotted two tiny holes close to each other in the very bottom of the rear cargo area.
The area does not show any signs of rust however.
Could these holes be there from start so that any water inside finds a way out?
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: tiny holes in trunk
If i recall there should not be small holes. There should be one large one in the center and that is it. More then likely PO was having hatch leak issues and decided to drill a couple of holes to allow water to drain.
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
