1984 camaro exterior trim
Old Nov 28, 2014 | 10:10 PM
chevyguy1999's Avatar
I am prepping my 1984 camaro for a new paint job and i had no problem at all removing the trim from the front nose clip and under the doors but i cannot get the trim on the rear bumper off. There is about a foot piece behind the rear wheels and i took out the screws that hold it from the bottom and i tried sliding it both up and down and it does not budge and im quite afraid of breaking it if i apply anymore pressure. And also the long piece under rear bumper i have the push pins out of but it seems to connect to the other piece i cant get off.. So if anyone has taken it off and knows how it comes off better than i do i would greatly appreciate some knowledge!
Old Nov 28, 2014 | 11:55 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 1984 camaro exterior trim
The qtr panel pieces have two nuts each on the inner qtr panel & the bumper also has 2-3 10mm nuts per, securing it to the qtr panels.For these you'll need to remove the interior plastic (dr.side) & the spare tire cover, plus the piece behind the taillights.
The taillights also need removing as there are plastic rivets under them holding the top of the bumper inplace.
Old Nov 29, 2014 | 03:27 PM
Thank you
84z96L31vortec
Aug 20, 2017 12:16 AM
chevyguy1999
Aug 16, 2015 08:49 PM
GVMV
Aug 16, 2015 08:01 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
