Crack by door corner - 91 Trans-Am
Old Dec 3, 2014 | 08:21 PM
Roger Davis's Avatar
Car: 1991 Firebird TA, 1G2FW23F3ML202439
Engine: 5.0 TP injection
Transmission: 5 speed manual
My passenger side door has a crack at the top rear corner, about 3/8" long. It looks like a fatigue crack, especially considering the location. I don't know how long it's been there, but I guess it's slowly growing. The driver side door may or may not be developing a crack, I can't be sure even with a magnifying glass, but there is a tiny spot there in the same location.
The car has about 96,000 miles.
The real questions are:
1) Why
2) How to stop the growth and repair the crack.
Old Dec 3, 2014 | 09:29 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Crack by door corner - 91 Trans-Am
It is from the car flexing. ( sub frame connecters can prevent that from happening and will stop that from coming back once fixed properly. )
I had one on each side.
Just before paint he fixed them the same way he shaved the antenna.
He removed some material from the crack making it a little wider and smooth.
Then he placed a thin metal plate behind it and ran a weld bead over it.
Smoothed the weld down and the crack disappeared "totally"
Old Dec 3, 2014 | 09:36 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Exactly what Ron said.
Subframe connectors will prevent it from happening in the future after you fix it.
Old Dec 4, 2014 | 01:35 AM
Will bolt-in subframe connectors be good enough for less than extreme use? Which ones are the best bang for the buck, and not so hard to install?
Old Dec 4, 2014 | 05:37 AM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
NOPE, bolt holes will elongate after a while, better to install the weld
in type SFC's . Shouldn't cost too much to have someone weld them in, just make sure you remove your carpet first.
Old Dec 4, 2014 | 04:47 PM
I understand.
Once properly done, will that be enough to stop the crack, and repair it with normal fill and paint?
Old Dec 4, 2014 | 05:44 PM
Engine: LB9, LS1
I understand.
I would get it welded, and then smooth it over with filler. Even with SFCs, these cars flex a little, enough to crack the filler easily.
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
pimprs
Sep 10, 2015 03:34 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
SG91camaro
Sep 5, 2015 10:27 PM
