iroc fender compatabilty
Old Jan 29, 2015 | 06:15 PM
bladehand's Avatar
Car: Iroc z 1990
Engine: 5.7 tpi flat top pistons
Transmission: 5 speed
Looking to replace passenger fender on my 90 iroc, believe 88-90 are identical, I used a 91 rs on drivers side the only difference is slots instead of hole for mounting chin, so I assume the 92 is the same, but are the 86-87 also the same? I noticed some of the other models have badge holes mid height, anyway are 86 through 92 the same in mounting to body and marker light placement?
Old Feb 1, 2015 | 10:21 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: iroc fender compatabilty
Iirc 82-90 and 91-92 (OEM) are two part numbers. Aftermarket are one part number for 82-92. Firebird, Trans Am, and vert. Camaros use different part numbers and break years. Mounting holes for emblems, ground effects are different depending on year but can be added (drilled) or removed (welded) as needed. The mounting to body and market light location will be the same on all years.
Old Feb 5, 2015 | 08:08 PM
bladehand's Avatar
Car: Iroc z 1990
thank you, just checking before I find out the hard way
Old Feb 7, 2015 | 06:23 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Besides convertibles, all Camaro fenders are the same stamping. '91-'92 have a different part # because of the slots for the front spoiler, rather than the holes. No fenders had holes for emblems, just for the spoiler and rocker GFX, if equipped.
BlueIroc-Z
Jun 9, 2019 03:22 AM
kah992
Aug 19, 2015 02:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
