Front fender splash sheilds
Old Feb 24, 2015 | 10:13 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Where is the best place to get new splash shields for the front? Mine are old and crusty and are looking gray.....
Old Feb 24, 2015 | 11:26 AM
82tarecaro's Avatar
Re: Front fender splash sheilds
I don't think anyone has them new. Sometimes an NOS set comes up on Ebay. To make matters worse, they were redesigned several times over the life of the third gens so it is tough to find the proper ones for your car. You will probably have to settle for cleaning yours up or hoping for a decent used set.
Old Feb 25, 2015 | 08:14 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Than can be painted as well. Just have to be prepped correctly.
Old Feb 26, 2015 | 07:32 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
I have the same issue. What is the correct way to prep them and then what paint should I use?
Old Feb 27, 2015 | 04:03 PM
stealtht/a's Avatar
First part of prep is to make sure they are really super clean. Scrub , scrub, scrub with degreaser. Sand out any imperfections if you care. Then clean with a wax and grease remover surface prep like Ppg dx330. Then spray on a plastic adhesion promoter. Finally use paint if your choice. Primer isn't really necessary but if you want use an epoxy primer as urethane or polyurethane primers are not flexible enough. You can get away without using flexible additive in final color if you are really carefull not to flex it while installing.
Yes, the paint will eventually chip off depending on how rough your road surfaces are. Up side is that grease is much easier to clean off.
If you want to avoid painting, some discoloration can be reduced by using a heat gun lightly over the surface after cleaning, but only works so well. Heat gun can also remove some overspray that acetone won't. Don't soak liners in acetone, it will eat it eventually.
Old Feb 27, 2015 | 04:34 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
That helps a ton! Thanks
BlueIroc-Z
Jun 9, 2019 03:22 AM
deracer
Apr 11, 2016 12:04 AM
fbirdroller
Sep 2, 2015 10:27 PM
kyleb24
Aug 15, 2015 08:24 AM
Amillionoh7
Aug 7, 2015 01:24 PM
