D/A Sander/ Compressor, Please Help!
Old Jul 8, 2015 | 10:27 PM
blktransam's Avatar
Car: 1988 and 1987 Trans Ams
So I just bought this...
and this:
Is not cutting, AT ALL.
My D/A Sander requires 5 CFM...
What is the smallest (cheapest) compressor that will keep up with Sander?
I've seen a bunch of compressors that say: 6 SCFM on them...
Is that adequate?
Thank you so much!
Old Jul 8, 2015 | 11:27 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
Re: D/A Sander/ Compressor, Please Help!
you need 25 gallon min. and still it wont shut off youll be spending time waiting to refill tank d/a run alot of air most of the compressor rate inital start up and quickly dieout plus the noise of the oilless compressor will drive you mad ideally 100 gallon oil compressor (kind with external belt) now you talking 220 volt no win situation it will take a LONG time to da a car that size sorry ( you need volume ie. tank size no residential compressor will keep a da happy with just the compressor) also you have a min and max pressure the tank starts and stops so accually you only use a couple gallons of air before it starts again so without spending hundreds of dollar its not possible
Old Jul 9, 2015 | 01:15 AM
Night rider327's Avatar
Car: 1988 Camaro
Yeah that little toy compressor is not going to do it at all.
I have an IR 60 gal, 220 volt, 11.3 cfm @ 90 psi compressor and it just barley gets the job done when using high air draw tools like the D/A sander.
You need to look at what pressure the cfm is at. The D/A sander needs 90-100 psi air pressure to run.
Alot of compressor companies will show you the big bold 6.5 cfm rating to fool you.. Look close and you will see that's at 40 psi or so
To work pretty good you need a min of 1.5 X the cfm as what the tool says really.
To work really good you need about 2.2 X what the tool says
Your D/A sander says 5 cfm, you need atleast a compressor that puts out 7.5 cfm @ 90 psi, and that's bare min. To work like it should you would need 11 cfm @ 90 psi
Here is what I recommed
$680 http://www.maxtool.com/ingersoll-ran...ght-11-3-cfm-s
That is the same one I have. I had mine going on 15 years now.
http://www.maxtool.com/belaire-3-5-h...cfm-at-100-psi
If you can only go with 115 volt units
http://www.maxtool.com/belaire-2-hp-...cfm-at-100-psi
If you can swing the price and run 220 volt line to it, you will NEVER regret getting a 220 volt, 60 gal compressor.
I have a whole host of air tools that I run on mine almost daily that a small unit would not be able to run.
700 ft lbs impact
3" cut off tool
die grinder
6" d/a sander
in line long board sander
drill
body saw
rivet gun
4" angle grinder
sheet metal nibbler
paint guns
air hammer
nail guns
Old Jul 9, 2015 | 03:23 PM
blktransam's Avatar
700 ft lbs impact
3" cut off tool
die grinder
6" d/a sander
drill
body saw
rivet gun
4" angle grinder
sheet metal nibbler
paint guns
air hammer
nail guns
I don't think I can swing a $680 compressor....
What about electric D/A Sanders?
Old Jul 9, 2015 | 09:20 PM
mk1431's Avatar
if you plan on doing your own work on the car 60 gallon one like above you wont regret it 230 volt otherwise have a shop do the work will be alot more invest in the future
Old Jul 9, 2015 | 09:53 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
You could scan local ads for a nice used one,
Old Jul 9, 2015 | 09:55 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Most small compressors are between 3 to 5 psi per second the low number is maintained pressure and the high is constant run with time to build pressure
Just get a 110 volt orbital sander and some good sanding disks
I did my car with a orbital 220 grit to 400 then wet sanded with 400 then 600
Came out great by the way
Old Jul 12, 2015 | 09:02 PM
Billgluckman's Avatar
I bought a 29 gal compressor from harbor freight and regret it. Get the biggest you can afford.
Also, google linking/combining 2 compressors. It may be a cheaper option for you.
Old Jul 15, 2015 | 12:44 PM
blktransam's Avatar
Is this what I need?
http://kansascity.craigslist.org/tls/5120487613.html
Old Jul 15, 2015 | 12:46 PM
blktransam's Avatar
Well,
I've already bought a Air DA Sander, and I'm going to need a good compressor for spraying primer....
Old Jul 15, 2015 | 12:54 PM
blktransam's Avatar
http://kansascity.craigslist.org/tls/5108175253.html
Old Jul 15, 2015 | 01:33 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
I know a few guys that use electric. Thats what id do if you dont want to buy a compressor...
Old Jul 15, 2015 | 08:58 PM
If that compressor was local it would be mine.
Old Jul 15, 2015 | 10:20 PM
steve87ta's Avatar
Engine: 461,305TB
Looks pretty good to me. I have one similar, painted a few cars with it.
Old Jul 16, 2015 | 05:09 PM
Car: 1988 Camaro
Both of those compressors will get the job done real well
Old Jul 17, 2015 | 01:18 AM
phasevariance's Avatar
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
I'd buy that now if it were local to me. Good luck with your paint project!.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
