84 bumper cover repair?
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
Hey, does anybody know in here how to properly repair the warping indented look to the top front section of a bumper cover? I've gotten use heat gun and ice comment, is there a method video or instructions for this?
Car: 84 Z28
Engine: 383 Stroker
Re: 84 bumper cover repair?
I have messed around with this before. In fact my whole front bumper was deformed. I had to put it in the HOT sun so it got soft and pliable. Then I made a jig to hold it in its straight position. It was a lot of messing around. There should be a thread here with pics. (You can make a tent too and put a heater under it.)
If you want the front spots(left/right side of emblem) to stay up, You will have to make some supports from the headlight rack to permanently hold them up. The sun/hot days will make it sag again otherwise.
-Dan
(edit) Make sure its good and soft and go super easy when straightening. Otherwise you may get spider cracks. They will be deep and into the plastic deep. Only way to fix is to sand them out or I know there are plastic specialists out there, Last I heard was around 200 bucks. Those 84 bumper/chin are hard to find in good condition arnt they...
good luck man.
-Dan
good luck man.
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
Thanks, for the info. Yes they are hard to find without paying the same price as a new one.
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
