Turn signal lever part number?
Old Dec 19, 2001 | 08:29 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I'm not sure if this is the right spot for this, but its an interior part so I'll give it a shot. If its not, sorry, just move it please.
Anyway, my turnsignals didn't work when I got the car, so I replaced the flashers and then they kept blowing the fuse. So I put a circuit breaker in and all has been fine until now. Now when I flip the turn signal on, it won't blink, it just stays solid. When I do the right one, it often gets stuck on when I return the lever to the "off" position. My dad said it could just be the lever, does that sound reasonable? If so, whats the part number on a new one so I can start lookin for one cheaper than at the dealer. Thanks guys.
Old Dec 20, 2001 | 02:37 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
What lever you have now? Cruise? Delay wipers? there are a bunch of different ones.
Inside the column, there are the guts that turn the signals off. That might be messed up and not the lever.
Old Dec 20, 2001 | 08:21 AM
Car: 1989 IROC-Z
Engine: 383 stroker
The lever I have now has cruise and delay wipers. Its from an 89 IROC, if that helps.
Old Dec 20, 2001 | 10:46 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Chanses are it does NOT sound like the actual lever. If you buy a lever, your only going to get a stick that you plug in. It sounds more like the actual switch inside the column.
As for the light staying on, check & make sure you don't have any burnt out bulbs... I have actually seen that happen. What happens is the fuse that "clicks" to turn on & off your blinker does not get enough current to trigger the reaction. Inside the blinker there is a contact that when it gets hot it breaks contact, then when it cools slightly it reconnects the contact & it cycles. If there is not enough current to heat up the reaction, the light could just stay on.
Thats how I understand it...
John
Old Dec 20, 2001 | 10:48 AM
okfoz's Avatar
After re-reading your post, start chasing the wires in your car to make sure there is nothing grounded out...
John
Old Dec 23, 2001 | 05:54 PM
nagga's Avatar
i need one too cause i cant use the dimmer switch, its $140 bucks from the dealership, not sure wut the part# is but i called, and they told me to look in a junk yard before buying one....
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
armybyrd
Aug 10, 2015 09:23 PM
Fronzizzle
Aug 9, 2015 01:15 PM
