T top locking mechanism
Old Apr 10, 2016 | 07:15 PM
bbernardo94's Avatar
Car: 86 camaro
Engine: 305 5.0L
Transmission: a4
I have these old t tips on my 86 camaro now that need to either be repaired or replaced. A buddy gave me a set of t tops that are close to new, but the only problem is they have a hook latchin mechanism while the old ones have pins as the locking mechanism. Is there any quick conversion to allow the hooks to fit in place? Or do I have to find different ones/ fix the old ones. Any advice helps!
Old Apr 10, 2016 | 11:06 PM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Re: T top locking mechanism
It will be a lot easier to just buy a different pair or to restore the old ones. The glass will work for all thirdgens but it will be a pain to separate the glass from the rest. Especially when you can get a set of tops for like $40.
Old Apr 11, 2016 | 05:47 AM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Or you can replace the latches under the puller posts on both sides. I had the same
problem I might have a couple of pairs in my shop if you need them.
The latch mechanism I think are not as safe as the rod. Friend of mine lost his
Top on the highway was not latched properly.
Abubaca
Dec 16, 2020 01:02 PM
Gecz28
Convertibles
May 6, 2016 02:27 PM
CamaroBlues
Apr 1, 2016 11:28 AM
gnilson
Mar 24, 2016 07:03 AM
