Removing ground effects
Old May 10, 2016 | 10:48 AM
Ezrider83's Avatar
Just wondering if there is a way to permanently remove ground effects from our cars, specifically an 89 Trans Am, without it looking like trash. Would you just have to fill in the screw holes or is there more to it?
Old May 10, 2016 | 12:11 PM
AmorgetRS's Avatar
Re: Removing ground effects
You would also have to replace the front and rear bumpers as you can't remove the ground effects from them.
Old May 10, 2016 | 12:28 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Wow Ezrider13 most people buy those not throw them away. Hell ive been buying extras. I actually threw away a Formula front and rear bumper I figured no one would want em.
Old May 10, 2016 | 12:50 PM
AmorgetRS's Avatar
To add, it would probably be cheaper to just sell the 89 TA and buy a Formula unless you have some special attachment to the car.
Old May 10, 2016 | 02:21 PM
turd_gen's Avatar
Car: 1985 Trans Am
I'm in the process of doing this on my '85 Trans Am.
I picked up an '85-'90 rear bumper, still looking for a matching front. It's funny, most people throw them away when they do a GTA clone and it makes it hard to find good Firebird bumpers.
The most time consuming part will be filling in all the holes in the doors and rockers, but I'm sure you've already discovered that. Also, if you haven't removed your GFX yet, be prepared to find some rust. On thie bright side, you'll be able to repair it before it becomes a bigger problem.
Old May 10, 2016 | 03:10 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
The ground effects on the rocker panels mount on a sheet metal flange that is spot riveted to the rocker panel. That will need to come off too.
sonjaab
Apr 28, 2016 04:20 PM
dpmalibu
Apr 26, 2016 06:32 AM
aljohnsonii
Apr 16, 2016 11:12 PM
siuol
Apr 16, 2016 07:09 AM
83mse66
Exterior Parts Wanted
Apr 16, 2016 02:19 AM
