Stress cracks on body
Car: 1987 Pontiac Trans Am/GTA
Engine: L98 350 TPI,
Transmission: 700-R4
Axle/Gears: 9 bolt w/ 3.23 posi
I have a couple of stress cracks just above the door glass on both sides, they run about 2 inches long. I'm not sure if it's fixable or am I better off parting out the car. It's an 87 GTA coupe. Any help is greatly appreciated
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Stress cracks on body
Not uncommon for these cars...unfortunately.The sooner you remedy it, the better.By itself, definitely not a reason to part it out.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
Had them on my Z as well, just like above just run a beed of weld and ground it down. It works.
Cool. I also have to replace the driver quarter panel. I appreciate the info. What kind of sub frame connectors do you guy's recommend?
Axle/Gears: 3.45, 3.27, 3.27
I prefer Alston SFC's and not just becasue I sell them. I've actually had them installed on my Canaro RS 'vert long before I started Top-Down Solutions. The things I like about Alston is:
1) They connect the front and rear subframes by the shortest route possible (less weight to add to the car).
2) They have a formed sheet metal cup that is forced onto the front and rear subframes providing a lock onto the subframe even before you drill and bolt them on or weld them on (welding is preferred).
3) Aready mentioned briefly, you have the option of drilling and bolting them on yourself, then driving to a shop to have them welded in later.
4) They are an inner-style of SFC and will therefore fit all versions of the car (hard top, t-top or convertible). Some brands are a perimiter-mount meaning they run along the pinch-weld just behind the GFX (if you have them). Those will not fit convertibles since the 'vert has a factory installed formed sheet metal reinforcement located there.
5) At under 20 lbs they are the lightest available.
6) Yes they stick down 1.75" below the floor pan, but since they are made from the same steel tubing that Alston uses to make their roll cages, they also help to protest your intermediate pipe from getting crushed.
7) Fit both single & dual cat exhaust systems.
Lon Salgren
Lon Salgren
For the common stress crack in the roof, drill a hole at the end of the crack, then weld it.
Lon
Lon
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
Since you (lonsal) sell them how much for a set? Been thinking of getting them for awhile. Thanks.
Just installed a set. Do it. These cars need them. And I recommend purchasing from Top Down Solutions for most reliable delivery in a reasonable time. I ordered for a slightly lower price elsewhere and it took two or three weeks to arrive, and there was no shipping or routing information supporting if/when they were shipped. You get what you pay for.
You don't need to register on the website to get a quote for S&H. Just put all the items you wish to buy into your shopping cart, then click on shopping cart in the upper right side of the screen. A menu will pop up in the middle on the left side of the screen. Click on "Estimate shipping & taxes", enter your country, state & zip code and your shipping options will be presented along with their cost.
Lon Salgren
89irocz355
26
Sep 12, 2016 01:28 PM
1992 Trans Am
Apr 4, 2016 04:06 PM
