Door rust repair help!
Subscribe
May 23, 2016 | 07:46 PM
I have little experience with bodywork, and can't afford to pay people to fix this for me. Under and around the crimped metal of the door, some kind of rubber/caulk seal lines it. On my driver's side door, it is cracking and rust is coming out from it. Has anybody dealt with this, or can give valid tips on how to remove the seal and reseal it? It is pretty tough, and I would like to know what I could use to seal it back once I solve the rust issue. On the last two images, it shows what how it should look on my passenger door. Thanks for reading!
Door rust repair help!-img_2890.jpg   Door rust repair help!-img_2891.jpg   Door rust repair help!-img_2892.jpg   Door rust repair help!-img_2894.jpg   Door rust repair help!-img_2896.jpg
Reply 0
May 23, 2016 | 08:26 PM
Re: Door rust repair help!
3m makes a fiber disc that is purple and that strips seam sealer pretty well. Once you get the sealer off you can sandblast it and then etch prime it, seam seal it and paint it again.
Reply 0
May 23, 2016 | 08:37 PM
Quote: 3m makes a fiber disc that is purple and that strips seam sealer pretty well. Once you get the sealer off you can sandblast it and then etch prime it, seam seal it and paint it again.
What can I use to seal it, and do you have any more information on the 3m part? Another thing. I don't have sandblaster, so I guess I would just sand it down and use a dremel to get it down to bare metal. Thanks for the reply
Reply 0
May 23, 2016 | 09:20 PM
Quote: What can I use to seal it, and do you have any more information on the 3m part? Another thing. I don't have sandblaster, so I guess I would just sand it down and use a dremel to get it down to bare metal. Thanks for the reply
Step#2
Step#4
Step#3
Step#1
Reply 0
May 24, 2016 | 03:48 AM
those little gravity fed blasters are great and the only way i will ever do rust repair again is by blasting.
Reply 0
May 24, 2016 | 05:27 PM
Quote: those little gravity fed blasters are great and the only way i will ever do rust repair again is by blasting.
What one do you use? Need a cheap little one but don't want to buy an poor build quality one.
Reply 0
May 24, 2016 | 06:38 PM
Quote: What one do you use? Need a cheap little one but don't want to buy an poor build quality one.
I use the harbor freight one. I put a dryer ball on it so I don't push moisture through and gum up the sand. It works really really well especially for the Price
Reply 0
May 26, 2016 | 03:59 AM
harbor freight gravity fed sandblaster combined with crushed class from northern tool for eight bucks for a 50 lb bag.
Reply 0
Subscribe
