87 camaro front ground effect question
Old Jun 4, 2016 | 10:12 PM
KingHD's Avatar
Car: 1987 Camaro
Engine: 350 HO 360whp
Transmission: Borg-Warner T5
I need some ideas on whether or not I need to replace the front end on my car in order to have front ground effects. When I get ready to paint the car I'm putting a z28 front end on it.
Reason I ask is I seen someone say that it would need done but it was on someone else's post and I didn't see the car.
1987 camaro
Picture of the front
Old Jun 12, 2016 | 06:23 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: 87 camaro front ground effect question
Yes, your front fenders could work but it's a lot of work to drill all those holes and fenders are cheap.
Your front bumper will not work at all
Drilling the doors, rocker panels and rear is not fun and the results often come out a little wonky.
There are thin long metal plates welded to the rockers for ground effects that you should add.
Just in case you don't know the rear bumper is different for non ground FX cars too
Old Jun 12, 2016 | 08:09 PM
Steve86TA's Avatar
Car: To many to list
If you are only changing the front bumper to the Z style, your front fenders are fine, you will only have to drill three holes in each to attach the side lower spoiler
gt4373
Mar 31, 2016 11:10 PM
xbmx89
South Central Region
Mar 29, 2016 02:14 PM
gt4373
Mar 23, 2016 11:09 PM
gt4373
Mar 22, 2016 11:08 PM
That Sky Guy
Mar 15, 2016 07:40 AM
