How do I remove my nose emblem for my 1992 camaro. I ordered a new one and see it has 2 studs with lock nuts I think, but how do I get access to those 2 studs on the emblem that's already on the car?
Thanks.
Thanks.
judging by that response it must be easy to get to. I haven't taken a look yet for an access point to the lock washer/nuts I'll take a look tomorrow.
Put the side skirt emblems and rear emblem on today, they look great and fit well. Let see how long the double sided adhesive tape lasts, hopefully a while. The side skirt emblems did come with studs and lock washers but my side skirts didn't have holes for them as the previous emblems were held on there by double sided adhesive, so instead of drilling holes into my side skirt I just cut off the studs of the new emblems and used the double sided adhesive tape that was on them.
If I recall, you just have to take out that black plastic panel in front of the hood latch. Carefully pry up the center pins and pull them out. I forget if there are any screws? you should be able to reach the back of the emblem from there
