rearview mirror
Old Aug 12, 2016 | 03:31 PM
keithl1967's Avatar
rearview mirror
OK--so this should be simple enough; however, I cannot get the rearview mirror to stay glued to the windshield...
I have gone through at least three trial with the permatex adhesive, and within a day or two, the mirror is invariably hanging by the electric wire.
Part of the problem, I believe is that the I should be gluing just the "button" to he windshield, and later installing the mirror to the button; however, a PO must have tried to repair and put enough glue that the mirror is not glued tot he button.
I"ve tried taping the mirror in place to help support while the adhesive cures, but alas, no luck...
Any tricks, or recommendations for something better than the permatex?
Old Aug 12, 2016 | 04:16 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: rearview mirror
You NEED to separate the button from the mirror for any kind of success.
Can you get the Torx screw out of the mirror mount?
You can destroy the button if you have to; they're available separately.
When you're ready to glue the button to the glass you need to have the glass CLEAN. ammonia-free window cleaner and newspaper works well. After the windshield is clean, use the towelette. With cyanoacrylate adhesives, more isn't necessarily better.
Old Aug 13, 2016 | 12:00 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: rearview mirror
Block sand the mount with fine sandpaper.
Once the mount is attached make 100% sure it doesn't move.
Hold 1 min at least w/ good pressure( not too much or you can crack the windshield).
My arm would tire, so I used my foot on the mount (don't laugh) leg wont tire as easily).Lasted 7 yrs until a couple weeks ago.
Wait at least 24 hrs before re-attaching the mirror.
Old Aug 13, 2016 | 03:28 PM
keithl1967's Avatar
Re: rearview mirror
Took it to safelite (only about 5 miles away)...they re-attached for no charge! See if it lasts...I suspect they use better adhesive than is available at parts stores...
Old Aug 14, 2016 | 08:53 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: rearview mirror
I've had the same lingering problem for 2-3 years; the mirror just falls off shortly after the button is installed no matter what the conditions are when I try to get it set. ( cleaning, temp, humidity, ect ) I thought I had FINALLY gotten the thing to stay in place this season,........ but then it fell off again yesterday on my drive out to a local car show. I've used the permatex adhesive several times,... no more ! I really need to find something else because I'm just throwing away $$ trying to use that crap !!
Old Aug 14, 2016 | 07:53 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: rearview mirror
My brother had the same issue, I believe it is the left over glue/ residue preventing it from making a good seal. We have a surface grinder at work so he took the metal plate that glues to the windshield and took a couple thousandths off. It has stayed on for about a year now,
89irocz355
Mar 28, 2018 08:24 PM
wgripp
Apr 24, 2016 01:18 PM
dpmalibu
Apr 23, 2016 03:59 PM
ken3983
Apr 19, 2016 02:48 PM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
