Maryland tag law
Car: 1992 Firebird
Engine: 3.1 6 cylinder
Transmission: 700R4 automatic 4 speed
Maryland tag law
I live in Maryland. I have a 92 firebird. I was wondering if anyone knew if it was required to have a front tag on the car. I did read that if the car came without a mount for a tag you do not have to have it on. But it must be in the car. Im not sure if that is true or not. Anyone know??
Car: 86 Iroc Z-28
Engine: 5.0 TPI
Transmission: Automatic
Re: Maryland tag law
here is what the Maryland DMV website says about it "Most vehicles must display tags on both the front and back, while others only need a rear plate. The MVA will issue the correct number of tags for your vehicle when you apply." Not sure what the requirements are for not requiring it.
http://www.dmv.org/md-maryland/license-plates.php
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
Im located in the same area(baltimore) as you and i have an 84 Camaro, from what i have acquired if you do not have a tag bracket it must be somewhere else that it can be seen(dash, etc.)
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
I bought a Formula in PA, which had no tag bracket up front. My solution was to buy a tag bracket that bolted in from the bottom- so no holes are made in the front of the bumper. Or, if you have some spare plate aluminum, you can do something like this...
(which I may do later)
http://www.corvetteforum.com/forums/...oductions.html
Engine: 2.8, 5.0
It IS mandatory in MD, I've been pulled over- even when displaying tag in the windshield.
Axle/Gears: 10 Bolt 2.73 Open
punkmaster98
Exterior Parts for Sale
May 9, 2016 09:48 PM
