PRD2L lights don't work (console lights)
Old Dec 27, 2001 | 01:15 PM
breathment's Avatar
i don't know if its one light or alot of lights, but they don't work, how hard is it to get to them?
Old Dec 27, 2001 | 02:05 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
I just finised changing mine on my 86 IROC. I took out the screws on the shifter plate and on the backside/bottom there is a light socket that will take a 194 bulb. It takes about three minutes. Let me know if you need anything else with this, I am more than happy to help.
Mark
Old Dec 27, 2001 | 02:53 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Actually on firebirds, you remove the Ashtray, & the 7mm screw under it. Then remove the 2 screws under the armest. pull up on the black plastic piece (gently) never broke one, but its plastic.
Then there is a tensie weensie bulb in the bottom of a white piece of plastic. Unscrew the bulb holder, pull the bulb straight out of the bulb-holder. Incert new bulb reassemble. It takes me less than 10 min. But I have done it before...
John
Old Dec 27, 2001 | 09:02 PM
Drew's Avatar
Ditto the above. The Firebird bulb is about $.18 at an autoparts store. Good luck finding one anywhere else.
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
