Front end damage, opinions?
Old Jan 17, 2017 | 11:43 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
My friends silver 85 iroc he recently got into a wreck with. Drivers side top rail is wrinkled front to back and the strut tower/battery tray is crushed in. I know looking at 2 pictures isn't ideal but would damage like this even be worth attempting to fix? Supposedly the car still drives ok
Old Jan 17, 2017 | 11:44 PM
Eric-86sc's Avatar
Engine: 305, 355
Re: Front end damage, opinions?
Old Jan 18, 2017 | 12:15 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
IMO - NO.
I'm betting that the front wheel(s) rub when turned all the way to one side or the other. With that kind of impact there's almost NO WAY POSSIBLE that drivers side frame rail is still in the original position.
Sure; anything can be "fixed". I wouldn't waste 1 more minute thinking about it,..... I'd be stripping it of all parts that are worthy and calling the scrap yard for a tow.
Just my
Old Jan 18, 2017 | 12:23 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Part it out or rip the front end off, make a fully tubular non-street legal drag car.
Old Jan 18, 2017 | 06:51 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
John has a point...there's probably additional damage your not seeing. I'd get the opinion of a good body shop as to the extent of the damage.
And John is also right that just about ANYTHING can be fixed. Check this out.
https://www.thirdgen.org/forums/memb...-firebird.html
That said, it will depend on cost Vs. value to the owner. I see it's had an LS swap. So it appears the owner is willing to spend some $$$ to build the car he wants. If there's an emotional attachment to this car, or he enjoys major body projects, a challenge, etc., then only the owner can decide how much is too much.
Old Jan 18, 2017 | 11:32 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
All that should be cut out -
Old Jan 18, 2017 | 01:07 PM
gt4373's Avatar
Transmission: 5-Speed Manual
You Ever See The Show Graveyard Carz,This Guy Restores Mopars From A Rusted Out Shell To Like They Just Came Off The Assembly Line. Like Others Have Said If You Have The Money You Can Restore Just About Anything.
Old Jan 18, 2017 | 02:48 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
All comes down to repair cost vs cost of another car/shell.
Yes it can be fixed. But at what cost?
Old Jan 18, 2017 | 02:59 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Can you restore this? Sure you absolutely can, but it's not worth it. If you did fix this yourself there is almost no scenario where it costs you less then buying another Thirdgen and transferring your good parts over. And unless you fixed this with a massive and beefy Jig or alignment rack there is no guarantee that the car would even be straight.
Old Jan 19, 2017 | 10:57 PM
Eric-86sc's Avatar
Engine: 305, 355
Thanks for the replies. I was hoping for not worth it responses. He was hung up on it being a "rare" color but finally saw the light after we found about 20 decent sub $1500 cars. Way cheaper then fixing the frame damage on the other.
