Passenger Mirror Help?
Old Feb 1, 2017 | 07:36 PM
That Sky Guy's Avatar
Hi all, I have a question about my passenger mirror. I changed the glass recently. The part that holds the glass is attached to the power window assembly with a cross shaped part; I can get one side of the cross in, but not the other. How do I get both sides in?
Thanks in advance!
Attached Thumbnails Passenger Mirror Help?-mirror-1.jpg   Passenger Mirror Help?-mirror-2.jpg   Passenger Mirror Help?-mirror-3.jpg
Last edited by That Sky Guy; Feb 2, 2017 at 07:22 PM. Reason: Wasn't clear enough.
Old Feb 2, 2017 | 01:44 AM
Drew's Avatar
Re: Passenger Mirror Help?
What starts to sag? The mirror glass? What do the power windows have to do with the mirrors?
Seriously, if you can't communicate clearly what you're trying to fix, how can anyone help?
Old Feb 2, 2017 | 01:47 AM
Apologies. Allow me to clarify.
I changed the glass recently. The part that holds the glass is attached to the power window assemble with a cross shaped part. The whole assembly sags; it doesn't stay upright, gradually falling down where I can't use it.
Old Feb 2, 2017 | 02:02 AM
Drew's Avatar
Changed which glass? The mirror glass isn't attached to the window in any way. When you say "power window" do you mean the power mirror motor? What is sagging? The door? The window? The mirror body? The mirror glass?
I'm sorry, I'm trying, but I can't make sense of what you're saying.
Old Feb 2, 2017 | 05:51 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
There are 3 screws holding the PM assembly to the housing. You can barely get to them with a screwdriver when the mirror is adjusted out of the way.
Is the cross still snapped in?
Are those screws still snug?
Did this occur after changing the glass?
What have you observed inside the housing?
Old Feb 2, 2017 | 07:23 PM
All:
I updated the OP with pictures... that cross shaped part is giving me a hassle, so it seems.
Old Feb 2, 2017 | 07:28 PM
jmd's Avatar
jmd
It snaps in. Push hard.
CLICK!
Old Feb 2, 2017 | 08:30 PM
CLICK!
I'm afraid I'll break it, haha... but I'll definitely give it a shot. Any more advice?
Old Feb 2, 2017 | 11:54 PM
Drew's Avatar
Looks like you're missing the pegs that engage the mirror backing to the motors. The cross shaped gimbal allows the mirror to pivot L-R & U-D. Without the drive pegs, even when you get the gimbal snapped in it'll still flop around.
Old Feb 3, 2017 | 10:44 AM
Those are the small circles that attach on each side, right? If so, they're still there... probably shouldn't have used a flashlight to take a picture at night, lol.
Old Feb 3, 2017 | 02:35 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Good call !
The proper way to replace busted mirror glass is to smash out the old glass and then remove all the busted glass pieces. Your not supposed to pull the bracket off the motor when replacing just the glass.
The "cross" piece/bracket should have been installed on the motor BEFORE you installed the new mirror glass. Otherwise your only option is to push the parts together, and this usually leads to breaking the new glass. Not always - you MIGHHT get lucky - but it's very likely to happen.
IMO your best bet is to remove the new glass, install the bracket ( & "cross" ) by pushing it back onto the motor, then re-install the glass again. FYI: I've had the unfortunate luck of busting that "cross" twice when repairing mirrors,... so make it as easy as possible for yourself because if that "cross" gets busted you'll probably need to replace the mirror guts. There is MORE than 1 type of bracket - they are NOT all the same from 82-92.
Old Feb 3, 2017 | 07:37 PM
Good call !
Lots of useful tips... definitely going to go take care of it!
