Could you order a thirdgen with ground effects the same color as the car's body?
Old May 8, 2017 | 07:03 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
I typically see ground effects on thirdgens that are an accent color to the body of the car. Were most thirdgens painted this way? Was it possible to order your car with ground effects that matched the body color?
Old May 8, 2017 | 07:28 PM
L67ss's Avatar
Re: Could you order a thirdgen with ground effects the same color as the car's body?
Most third gens I've seen had them matched to the body like my brothers 88 iroc and two friends respective 87 irocs. Both my 84 rs and 88 rs also had color matched. Accent colored ones just looked better
Old May 9, 2017 | 09:16 AM
Drew's Avatar
Serious question? Uh, all Iroc's, RS's, GTA's, are monochrome. Accented GFX were a requirement on early Z28s until 88, and the Trans Am until about 85. Monochrome paint was optional on the Trans Am until about 1990, then it was standard til the end of 92 production. The 88 Camaro sport coupe was the last Camaro with silver or gold GFX.
So that's probably not quite 50/50 since popularity peaked between 84-87, but it's still a lot of cars.
Old May 9, 2017 | 05:41 PM
battmann's Avatar
Sorry - guess I should have been more specific. I was mostly wanting to know about early ones - like 82-84. I have a 1984 TA.
Old May 9, 2017 | 06:50 PM
Drew's Avatar
82-84 for the most part you had silver or gold GFX, with some notable exceptions.
Old May 10, 2017 | 04:09 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
This(Firebird Order Sheet) is what you could order in 86,I'm sure the other years are similar
