Steering Column Problem
Old May 12, 2017 | 09:03 AM
rgauder's Avatar
Car: 1987 Trans Am
Hi guys.
I had the loose bolts in my tilt column, so I tore it down and tightened them up with Locktite and reassembled, but because the pin removal tool broke off in one of the pins, I had to remove the column. Now I'm trying to put the column back in and have run into a problem:
I get the column flush against the firewall on the inside, but it barely inserts into the steering shaft under the hood. I mean just barely inserts. What do I do?
Old May 12, 2017 | 09:07 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Steering Column Problem
the steering shaft extends. pull it onto the column at the joint near the booster. may take some effort.
Old May 12, 2017 | 09:12 AM
rgauder's Avatar
Car: 1987 Trans Am
Seems like I'm off a little more than an inch.
Old May 12, 2017 | 09:40 AM
rgauder's Avatar
Car: 1987 Trans Am
Also seems like a good time to upgrade to an Astro shaft.
Old May 12, 2017 | 06:11 PM
rgauder's Avatar
Car: 1987 Trans Am
Shaft was collapsed. Had to undo the rag joint and take it out to extend it again. It's all back together until my astro shaft gets here.
