5/16 hood bolts
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
5/16 hood bolts
So my fiberglass hood is tapped for 5/16 bolts. The holes in the hinges are only 6mm which is basically 1/4".
I think 5/16" is too big even for a helicoil. Any suggestions other than trying to bore the slots in the hinges larger?
-- Joe
-- Joe
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: 5/16 hood bolts
Mine also...open up the holes.. (Glastek hood)
I had to open up mine. and slot them. to get the hood on the way I wanted..
the pic below shows them (the holes) then chromed after fitting...(just below this..you can see the holes open/sloted)
the fit was 100% to my liking after opening & slotting..
Re: 5/16 hood bolts
Fabricate adapter studs - 5/16" hood thread on one end, and 1/4" or 6 mm on the other. You might even be able to buy them.
Similar to this: https://www.summitracing.com/parts/r...yABEgJ9J_D_BwE
and this: https://www.newport.com/f/thread-adaptors
M8 to M6 is easy to find. The threads in your hood might be 5/16, but M8 might be close enough to thread in.
Darkshot
Aug 5, 2009 07:35 PM
scanman717
May 10, 2004 01:45 PM
88305tpiT/A
Aug 21, 2002 11:07 AM
branz28
Apr 2, 2001 11:21 PM
