door "jumps"
Old Jan 4, 2002 | 08:27 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
door "jumps"
when i hit bumps in my ttop firebird, the kind of pivots up and down making a loud noise. does anyone else have this? is it common? How do i fix it? Also throughout the history of the car a lot of people have closed the doors by the windows and now they are "loose", they go up and down okay but they rattle back and forth, how can i fix? please any help asap appreciated, please.
Old Jan 5, 2002 | 07:28 AM
KeithO's Avatar
It sounds like your door hinge pins are worn out. To find out for sure, open your door all of the way, then gently lift up and down on the door. If there is play, your hinge is worn and needs servicing. I have the same problem...
If this is the situation, check the other threads for "sagging door", etc for a full series of dialogs.
This is a common 3rd gen problem.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
kkirch15
Sep 30, 2015 04:44 PM
