notch back glass and seal/gasket
Old Mar 10, 2018 | 09:06 PM
Irishamericanld's Avatar
Car: 1992 firebird
i got a no brand notchback a few years back and the glass ( in this case, plexiglass) i was attached via several spring loaded brackets.. but want to replace it with real glass and gaskets .. it was a pretty crappy silicon caulk job lol
.. any ideas will be greatly appreciated. was thinking i using a pinch gasket but didn’t know what was available .. also does anyone recognize who made this ?
Old Mar 12, 2018 | 08:51 AM
Car: 1992 firebird
Re: notch back glass and seal/gasket
i did message Hawkes to see if they sell the gasket and glass seperate and they said no bueno...
Old Mar 13, 2018 | 07:58 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I don't think that a pinch gasket would seal very well. I would use urethane, like on the front windshield, permanant and no leaks if done properly. Caulk is never the right product for this application
Old Mar 13, 2018 | 08:02 AM
Car: 1992 firebird
thanks for replying
there is no indention or lip to lay the glass into like on a windshield .. so either i would have to dremmel a lip into the existing frame or use urethane directly over the window on the frame but that would cause there to protrude out.. i make film props so i am comfortable lining out and using a dremmel to craft that .. just was hoping to find the proper way it was supposed to be ..
Old Mar 13, 2018 | 08:37 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The purpose of the urethane is to fill a gap and bond to the substrate, so it doesn't matter if there is a channel for the windshield to sit in. Once it is glued in no one will know how it is there from the outside. I believe it is that way on the factory notchback, the rear window is just glued in, and then has clips to "hold it" in place. Mine is a mess and I will have to make a few repairs.
Since there is that channel at the bottom of the window area, I would just put a small mount in there, and then an even bead around the raised window support area and keep it flat while it cures, then put the clips back on and be done with it. Cutting the fiberglass is going to make an already weak item, weaker
Old Mar 13, 2018 | 03:55 PM
Car: 1992 firebird
cool thank you
Old Mar 13, 2018 | 07:21 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Would something like one of these work? Glass in one channel, body edge in the other?
https://www.alibaba.com/product-deta...315612411.html
https://www.alibaba.com/product-deta...126225089.html
http://www.sealrubberstrip.com/winds...therstrip.html
http://www.perfectfit.com/15976/1541...pment-Etc.html
BlueZee28
Exterior Parts for Sale
Apr 21, 2012 07:28 PM
ted gerlach
Interior Parts Wanted
Nov 11, 2008 04:32 PM
86bird_28v6_5spd_ramair
Oct 8, 2001 12:22 PM
MattW
Jul 11, 2001 11:59 AM
