Touch Up Paint for White IROC.
Old Mar 13, 2018 | 01:06 AM
KanzlerBismarck's Avatar
Car: '89 Iroc 5.7
Axle/Gears: G80 Posi/LS & GH3 2.77
Hey guys, I am looking for the correct white touch up paint for a 40U 1989 Iroc. I cannot seem to find a company that will commit to 40U being the same white as the white used on my car.
Anyone have any luck with any touch up products?
Old Mar 13, 2018 | 01:27 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Touch Up Paint for White IROC.
I feel your pain. I got the correct code touch paint from the Chevy dealer, not even close. Auto parts store, not even close. Had the car scanned at the body and paint store and bought a quart - closer. Went back and someone tinted it with some ochre, still closer. That is a pain in the butt color to match.
Old Mar 13, 2018 | 02:12 AM
Car: '89 Iroc 5.7
Well.. at some point I'll just repaint the whole damn thing than...
It only has rock chips and a 4" x 1/2"spot on the hood that I used some white to paint it out... and while others don't see it....
Old Mar 13, 2018 | 08:24 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
40U only means that your cars color is primarily White. You need the color code off your RPO sheet. In 86 the code for White was 8554
Old Mar 14, 2018 | 10:31 AM
86IROC112's Avatar
Car: 1986 IROC Z
I had a sandrail painted 1970 Dodge Challenger green. that real bright green almost neon color. I ordered some paint from paintscratch.com and they mixed it up and shipped it to me. Perfect match! Also had them make me some touch up paint for my Corvette that matched perfectly too.
Old Mar 18, 2018 | 09:29 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
You could try to have a shop match it and make you some.. might be a little pricey but I know guys that can match paint perfectly.. try a good body shop in your area that does show cars and restorations (not just insurance work) and they might help you out..
Old Mar 18, 2018 | 09:30 PM
Axle/Gears: G80 GU2
I’ve never found touchup paint that matches what it says it matches.. always had to mix it..
Old Mar 20, 2018 | 08:18 PM
Abubaca's Avatar
...add to that the fact that it may not be original paint....and if it IS, it's got 30 years of aging. That's the more likely culprit.
Old Mar 21, 2018 | 08:41 AM
mantaguy's Avatar
Engine: 5.0 EFI
99.9%
Coolwheels84
Members Camaros
Jan 15, 2017 07:08 PM
89chevycamaroRS
Jan 20, 2011 08:31 PM
AlkyIROC
Jan 7, 2010 11:50 PM
HighPressure
Dec 11, 2009 03:21 PM
camaro6spd
May 14, 2003 10:01 AM
